BMS or Attack Blue?
Old Feb 17, 2023 | 08:29 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Default BMS or Attack Blue?
I don't drive the car much so dirt isn't an issue. Should I go with a BMS air filter for a slight advantage over the Attack Blue?
Old Feb 17, 2023 | 03:54 PM
cdh027's Avatar
cdh027
Have they been tested head to head?
Old Feb 17, 2023 | 04:17 PM
BELVIN20's Avatar
BELVIN20
Save your money & get OE filter, neither one is not going to give you anything in horsepower unless you running wide open all the time.
Old Feb 17, 2023 | 04:22 PM
RocksZC7's Avatar
RocksZC7
I have used both filters and prefer the Attack Blue. This filter is washable and provides better filtration than the BMS. Both provide a small increase in performance.
Old Feb 17, 2023 | 09:21 PM
car2fast4you's Avatar
car2fast4you
I have the BMS filter and I can tell you that it provides a very noticeable increase in throttle response on my Z06. It also virtually eliminated the off idle stumble that is common on these cars.
Old Feb 17, 2023 | 11:01 PM
Shirl's Avatar
Shirl
Thank you for the replies everyone. I was looking into the BMS today and noticed they offer a filter to fit the OEM Jake air box. Anyone have that? Mostly for looks I guess, right?
Old Feb 17, 2023 | 11:02 PM
Shirl's Avatar
Shirl
This is great info. Does the filter increase the sound a little as well?
Old Feb 18, 2023 | 01:28 PM
car2fast4you
I didn't notice any increase in sound. Based on my research, the stock intake provides excellent air flow. The restriction is at the OEM filter. The BMS filter has a significantly larger opening, which seems to make quite a difference. It's supposedly much more noticeable on the Z06, which is what I have. The Blue filter should have similar performance.
Old Feb 20, 2023 | 08:57 AM
Shirl's Avatar
Shirl
Ok, thanks! I will probably just go with the BMS even though it's not washable. I don't drive the car enough to worry about a washable filter.
To BMS or Attack Blue?
