Sway Bars
Old Apr 25, 2023 | 11:42 AM
TwoStrikes's Avatar
TwoStrikes
Cruising
Default Sway Bars
Looking to get a little crisper turn in and handling. I have just got a DSC Sport controller and was looking at the previous sway bar threads but minimal feedback. I was looking for those with Hotchkis bars and what your feedback is.
Old Apr 25, 2023 | 12:00 PM
C7.R 004's Avatar
C7.R 004
Two.
I have limited experience with sway bars but I installed the AMT Monoball bushing kit in my '16 Z06 Z07.
amtmotorsport.com
Pricey but worth it to me.
Mark and his company are top shelf.
He has commented on CF and may be a sponsor.
Old Apr 25, 2023 | 04:44 PM
LagunaSecaZ06's Avatar
LagunaSecaZ06
I have the Hotchkis https://www.hotchkis.net/product/201...&md=440&sm=488
sway bars and have used them on my Z06 for the street and roadcourse for the past few years. The turn in is improved a little bit. My main reason for using them is the 3 way adjustable rear bar. I was able to soften the rear bar relative to the front. IMHO, the stock setup(Z06/Z07) has too much oversteer on the track. With the Hotchkis bar in the stiff setting the car definitely has oversteer if you lift off in the middle of turn at STREET speeds (25 MPH in a 90 degree turn). With the rear bar in the middle setting the car is neutral on the street and track. I have not tried the softest setting since the middle setting works great.
Old Apr 25, 2023 | 05:56 PM
Rdubfalco's Avatar
Rdubfalco
Might consider a complete Borg Bushing kit and LG Sway bars with their adjustable end links.
That AMT Monoball bushing kit mentioned above looks like good stuff too.
-Rich
Old Apr 25, 2023 | 05:59 PM
Rdubfalco's Avatar
Rdubfalco
Ever consider upgrading end links?
Old Apr 26, 2023 | 12:32 AM
TwoStrikes's Avatar
TwoStrikes
Cruising
Ive had various upgraded endlinks in other cars and I would prefer to avoid anything spherical on the vette. I saw the LG previously mentioned as "too harsh for the street" so thats why I was looking at Hotchkis.
Old Apr 28, 2023 | 06:49 PM
Brad Larsen's Avatar
Brad Larsen
The Hotchkis bars will definitely give you better turn-in and balance. But it does depend on the environment that you want to use them in and with what tires. I've used them successfully in both Auto-X and Track Days with Super 200 tires -- a big improvement over stock. But if you go to Hoosiers, you may need the LG bars and heim-style end links. What is your goal with this setup? And how aggressive is your alignment? I'd argue that the right alignment is the bigger difference.
Old Apr 29, 2023 | 08:39 AM
TwoStrikes's Avatar
TwoStrikes
Cruising
They will be used with the stock cup 2's or the ps4s, for spirited driving. Goal is just to get crisper handling on road without sacrficing too much driveability or comfort. Stock alignment.
Old May 1, 2023 | 07:45 PM
fatsport's Avatar
fatsport
I ran the Hotchkis bars for a while. The front bar is great, much sharper turn in. I thought the rear was a little stiff for my setup though. I ended up doing the Z07 rear spring instead.
I’ve sold my Z and still have the bars if you’re interested PM me. I’ll list them in the classifieds soon.
Old May 2, 2023 | 10:33 PM
Brad Larsen
The Hotchkis bars are a good fit for you then. As stated above, I'd start with the middle setting on the rear bar. If you get too much action/oversteer, you can still soften a bit.
To Sway Bars
