Bleeding intercooler
Old May 10, 2023 | 10:23 AM
c6txvette's Avatar
c6txvette
Originally Posted by RegnaR
Anyone have the bleeder system in Austin Texas?
looking too I’m in Houston
Old Mar 8, 2026 | 04:02 PM
Cody97's Avatar
Cody97
2nd Gear
Originally Posted by 9sec
im in the nashville tn area with a cooler bleeder if someone is having this issue. I have tried the clear tube bleed, a schwaben vacuum system bleed, a mityvac bleed and I stood there for 20 minutes and yelled at the car.
once I found a cooler bleeder used with all the attachements for 400$ shipped I bought it and used it. ended with more air than I had before!! tore my entire system apart looking for a leak and in the end I discovered I was using the bleeder IMPORPERLY at the end of the process . now I have 2 bubbles quarter size. moral of the story is
1. the cooler bleeder simply works the best
2. if you wont read the directions (like me!) then you need to be smarter than the equipment you are using!!
3. the inventor of the cooler bleeder ALTJAR is extremely responsive and helpful even when you haven't bought a system from him. cant say enough nice things get one and enjoy the process
Do you still have this by chance? Im near Nashville and need to bleed the system on mine.
Old Mar 9, 2026 | 04:53 PM
9sec's Avatar
9sec
yes I still have mine. if you want to stop by my house ill be happy to bleed the system. donations always accepted!! ill be heading to tx2k next week so after that im open
Old Mar 30, 2026 | 10:43 AM
LightningBrett's Avatar
LightningBrett
Anyone with a cooler bleeder near Atlanta? I have tried cycling the pump w/bottle of coolant above/attached to the bleed port. Didn't do much. Still have air in the reservoir......
Old Mar 30, 2026 | 12:00 PM
9sec's Avatar
9sec
4 hrs away road trip and then you could go to inn and out for lunch!!
