C.e.l p06dd
Old Nov 25, 2023 | 03:22 PM
chris9615's Avatar
chris9615
8th Gear
Default C.e.l p06dd
Hey guys, I was wondering if anybody experience this check engine light code plus the reduced engine power mode. Oil pressure idle is around 35 psi, I’m bringing it to the dealer this week but just want to know if anyone had this problem.
15 z06
Old Nov 26, 2023 | 10:53 AM
laserdude2215's Avatar
laserdude2215
With 35 psi at idle, the oil pressure control solenoid is definitely stuck off. (Assuming hot oil.) Changing it is a major undertaking. Good luck.
Old Nov 26, 2023 | 12:26 PM
chris9615's Avatar
chris9615
8th Gear
just drove it to the dealership for a diagnostic, now that the oil was hot it was idling at 28 psi. Cursing at 2k was around 35-38 psi.
you still think it’s stuck? I’m scared it’s going to be expensive, I’m out of warranty🥲
Old Nov 26, 2023 | 01:46 PM
laserdude2215
The dealer will be to activate and deactivate the solenoid with their scan tool software (GDS2) while monitoring the oil pressure. That will give you a definitive answer.
To C.e.l p06dd
