Intercooler System Dilemma
I have some suspicions (possible cooling block leak?), but nothing I can prove. Thoughts?
If your tuner doesn't have a Cooler Bleeder they aren't going to be able to get all of the air out.
If there is a leak in one of the bricks that would cause an engine issue as the coolant would be pulled into the cylinders being fed by that brick. When operating the system doesn't pressurize much since the fill plug is all that seals the system and there are no reports of people losing the plug when driving for long periods on a track where everything gets very hot.
Bill
see post #5
https://www.corvetteforum.com/forums...leaks-zr1.html
Manifold sitting on top of Snout:
Manifold removed showing coolant holes on Snout:
Different view of holes on snout:
Front of the SC showing where Snout attaches showing the 4 ports for the two bricks with O Rings around the ports:
Rear of Snout showing where the 4 ports from the bricks connect with the Snout:
Different view of rear of Snout:
Leaks might occur where the snout and the bricks connect (there are O Ring seals around each port on the bricks) and the bricks themselves can also leak. The dealer won't go any further than seeing if there is a leak in the SC. GM's procedure at that point would probably be to replace the O ring seals under the manifold and if that didn't work they would replace the SC which can be an issue since the 2017+ SCs are on backorder.
If there is a leak it is more likely going to appear in the HX or the hoses connecting the SC to the HX and the reservoir. The HX is the most likely place for a leak to occur since it is sitting in front of the radiator and the AC condenser and can be hit by road debris thrown up by other cars. Since the intercooler system isn't pressurized any leak would probably be very small unless there is a large hole.
So which 3 ports are you blocking and where is the 4th port where you apply pressure?
Bill
Bill
Regardless, it really shouldnt be a hard diagnosis. Sometimes leaks will only show up under vacuum, other times only under pressure. I wouldnt hesitate to put 1 bar of pressure on the system and then let it sit / monitor. If it holds the pressure, then go back to vacuum. Simply touching connection points and hoses, while under vacuum, can be enough to cause a vacuum gauge to jump around if the joint is leaking. Reach out to me at www.coolerbleeder.com if you decide to fix on your own and we can set you up with the necessary tools to pressure and vacuum test, as well as bleed.
