Water temp low
Old Mar 10, 2024 | 07:33 PM
Tbone005's Avatar
Tbone005
Default Water temp low
Been searching the Forum and I cannot find where the water temp sensor is located. One feed said top of water manifold and I don't see it. Found a sensor on the driver side and replaced it but noticed my water pressure is now high (75psi). I assume I changed the wrong one.
the issue I am having is that I am getting a low coolant temp trouble engine light. The temp gage stops around 150 which is causing the fan to run at top speed. I have looked around the supercharger and I don't see it.
Old Mar 11, 2024 | 12:02 PM
sammy burks's Avatar
sammy burks
Active Streak: 90 Days
The water temperature sensor is located on top of the water pump easy to get to driver side But I would reset the CPU first, grand wire off battery for 15 minutes
Old Mar 11, 2024 | 04:21 PM
Tbone005's Avatar
Tbone005
Default Update
Replaced the temperature sensor and took off the positive off the battery for 15 min. Went for a good drive today since it was a beautiful day. Temp came up to 190 and held around this temp(+-10) the whole time. Fan didn't not come on and run at high speed. Thank you!
To Water temp low
