High Flow Cats
Old Jan 10, 2025 | 08:31 AM
Akcajunz's Avatar
Akcajunz
Veteran: Coast Guard
Default High Flow Cats
I have a 2019 Z06 and I am wanting to install headers and X-Pipe. I'm and about to move to a state that has emissions inspections, so does anyone have any experience with "High Flow Cats" on the X-Pipes being good enough to pass an emissions test?
Old Jan 10, 2025 | 02:59 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
Depends on the state. CA is insanely strict, not even high flow cats will pass.
-Josh
Old Jan 10, 2025 | 04:43 PM
cdh027's Avatar
cdh027
Your first issue is moving out of Florida. Where are you moving too?
Old Jan 10, 2025 | 07:43 PM
Akcajunz's Avatar
Akcajunz
so why is moving out of Florida an issue? Are you from here?
Old Jan 11, 2025 | 11:05 AM
cdh027's Avatar
cdh027
No, I spent 50 years in Hellinois. Never going back to 6 month winters. Where are you moving to?
Old Jan 11, 2025 | 07:17 PM
Akcajunz's Avatar
Akcajunz
I’m originally from South Louisiana, went into the military 40 years ago, retired after 30 years. Now I’m about to retire again and probably move back home to Louisiana
Old Jan 13, 2025 | 04:20 AM
MorrisZ51's Avatar
MorrisZ51
-Josh
This is true but can they see the secondary cats on an x-pipe? Any CA guys here with an x pipe fail smog for this? I hope not, I like mine.
Old Feb 26, 2025 | 05:27 PM
Sideways23's Avatar
Sideways23
Cruising
Those are just resonators on X pipe. Last smog I had done on my 19C7Z they didn't look at much, didn't run a sniffer either, just plugged in let it check the ECM and off I went. Unless you are setting an engine light I doubt high flow cats would fail these days.
Old Feb 26, 2025 | 06:48 PM
MorrisZ51's Avatar
MorrisZ51
I believe they are cats not resonators. They are just not monitored like the primary converters. If the could be seen the car would fail the visual, fortunately you can’t see them.
Old Mar 5, 2025 | 03:21 PM
tlrskunk's Avatar
tlrskunk
You are correct.
They are secondary cats not resonators.
It's why Cat buyers will purchase them when you take them off.
Old Mar 7, 2025 | 08:51 AM
Internets_Ninja's Avatar
Internets_Ninja
As long as your destination county/state doesn't do "visual" inspections and look specifically for secondary cats, you will be fine deleting the rear cats or installing an X pipe with high flow cats. The front cats are monitored and cannot be tampered with in states that require emission inspections. If your state just does the plug in OBD2 inspection test, then you will have no issues with rear cat deletes or aftermarket X pipes.
Old Mar 10, 2025 | 01:17 PM
FORZAMOTORWORKS's Avatar
FORZAMOTORWORKS
Supporting Vendor
It really depends on how your region does testing, it varies widely. Visual, OBDII, sniffer etc
There are pros and cons to both catted and catless. What are your goals for the car?
We're dealers for Kooks, Stainless Works, American Racing Headers etc - happy to discuss options and extend forum pricing.
- Alec
__________________
Alec @ Forza Motor Works
info@forzamotorworks.com
www.forzamotorworks.com
Your trusted source for premium parts - offering competitive pricing, exceptional service, and professional installation options.
Corsa | Borla | AWE Tuning | Girodisc | Halltech | American Racing Headers | Milltek | Soler | Weld | Fabspeed | SOUL | Kooks | BC Forged & 100's more!
Old Mar 11, 2025 | 09:22 AM
cdh027's Avatar
cdh027
- Alec
Can you guys get Kooks for similar price to ARH? Both being kits with high flow cats.
Old Mar 11, 2025 | 10:01 AM
FORZAMOTORWORKS
Supporting Vendor
Let me check - I'll send you a PM
- Alec
To High Flow Cats
