DSX Flex fuel sensor install
1) i removed the wheel
2) removed all screws and clips in fender liner.
3)i had to remove 3 rivets from my side skirts to release fender , they are black and they dont come with the kit so be warned you will need them if you have an aero kit on your car .
4) removed all top torx screws for bumper , one is hidden int rear corner under the plastic trim where the end of the wiper is pointing.
5) have a magnet handy to remove the 10mm bolt next to the oil tank .
once all that is done there is lots of room as you can see in the images to snake the harness out to have all the room in the world to run the pin in .
The pin number is 38 , and there is a small protector in there that must come out , i used a electrical diag probe pin to push it out after you take the blue cover and the back clip off.
Cutting the wire harness zip tie makes it easier to locate pin from the top . Pay close attention to pin orientation when you push it in . That's pretty much it , rest is run the wire. I did add some loom to mine to make it look cleaner and give it a little more protection . Any questions let me know . This can easily be done with a jack and some jack stands no problem so dont be scare to tackle it on a weekend.
The loom i added to the small black wire needed to be ran to ecu
That’s the pin can barely see it though
That is the protector that has to come out
If you loosen the bolts mentioned you can see how much room you have.
I used my trim tools to hold fender in place
I slid the fender over the side skirt but added tape to it to protect it
but thanks for the heads up , I’ll try it when i get the car back together.
In regards to HPT , here are some things you can change in HPT not sure if it would have helped you at all . As you can see in the software there is even a frequency adjustment for the sensor. I will check it though just in case with my Oscope to see what the frequency this sensor sends out and if it matters if i change that table.
Did you ever ask DSX about the issue ? interested in what they said if you did.
I emailed DSX and explained the E content wasn't reading correctly and all he said was " The sensor is correct"... Obviously it wasn't after testing different fuels and replacing the sensor with one that actually worked properly. Its kind of like your car showing you only have 3/4 tank of gas after you just completely filled it up. You call the tech people and they say its reading correctly. You know damn well its not, so you replace the fuel sending unit and now it reads a full tank like its supposed to..
