Tires
Old May 13, 2025 | 04:21 PM
BIGDRAG's Avatar
BIGDRAG
4th Gear
Default Tires
Curious cant find anyone that has good performance tires (sizes) that fit my 2016 Z06 Corvette, any help?
Old May 14, 2025 | 01:38 AM
L2 Eray's Avatar
L2 Eray
You telling me Tire Rack, Discount Tires, and the like have all ran out of stock?
Old May 14, 2025 | 09:31 AM
Osuz06's Avatar
Osuz06
1st Gear
Missing some information here are you running stock tires or aftermarket? What do you consider "good performance"?
If running stock tires I also find it hard to believe the major tire websites do not have inventory in your size
Old May 14, 2025 | 03:59 PM
LSX228R's Avatar
LSX228R
R888R's are the best ones i've had. Not sure if they come in stock sizes for the c7z tho. I had them on my c6.
Old May 15, 2025 | 01:42 PM
Bill Dearborn's Avatar
Bill Dearborn
Define what you mean by performance tires. There is a wide range of performance tires, some are good on a road course, while others are best on the street and others are best on a drag strip. The best street performance tires for my Z06, I have found, are the stock Michelin PSS ZPs. They work well on the street, don't do too badly on the track and wear much longer than the Cup 2s.
Bill
Old May 16, 2025 | 02:50 PM
Exia's Avatar
Exia
Stock Michelins are great but also seem to be difficult to find at times and are expensive. I went with the Continental Extreme contact sport 02, cheaper and stock sizes. Still a summer performance tire.
Old May 16, 2025 | 02:58 PM
speed4tu's Avatar
speed4tu
discount tire should have anything you need available. They did as of yesterday.
Old May 16, 2025 | 07:25 PM
BIGDRAG's Avatar
BIGDRAG
4th Gear
Default tires
Wanting some good street?drag tires to perform, like R888 Toyo or Nitto but dont have in my size?
Old May 16, 2025 | 07:26 PM
BIGDRAG's Avatar
BIGDRAG
4th Gear
Looking for good performance racing style like Toyo or Nitto and dont have my size for some reason
Old May 17, 2025 | 01:52 PM
R3DRUM's Avatar
R3DRUM
You are going to need to go outside of stock specs a little bit. There are plenty of combinations that have been shown to work with both Nitto and Toyo, which are what I would say are your best two choices for a performance tire outside of Michelin. For example, I have 295/30/19 Michelin PS4S front, 345/30/19 Nitto 555R2 in the rear. This setup works very well for straight line applications and can still handle corners decently. You can also run the same size R888R out back. Personal preference, I've had R888R and I much rather the Nitto. You can also run a 285/30/19 MPS4S in the front and 325/25/20 MPS4S in the rear. Plenty of options especially if you drop down to an 18/19 wheel in the rear.
Old May 17, 2025 | 03:01 PM
BIGDRAG's Avatar
BIGDRAG
4th Gear
Noit trying to change my wheels, but use the wheels i have and with 19" in the front and 20" in the rear its slim pickens
Old May 17, 2025 | 06:24 PM
R3DRUM's Avatar
R3DRUM
There are multiple sizes that will work with stock wheel configuration for every major performance tire brand: Nitto, Michelin, Toyo, and Continental.
Old May 19, 2025 | 10:24 AM
hiltsy855's Avatar
hiltsy855
I recently got Toyo Proxes Sport tires. I up sized with 295/30-19's front and 345/25-20's rear on the stock wheels. I really like the fitment and don't have any rubbing even being lowered on the stock jacking bolts.
To Tires
