C7Z06 mods
Old Jun 24, 2025 | 10:52 PM
Shawnm32's Avatar
Shawnm32
Default C7Z06 mods
I have a 2016 Z06, A8 with only Haltech intake, taller sc lid, and an xpipe and catback exhaust from AWE….I have a quote from a local shop for BTR stage 2 SC cam, supporting heads mods, DOD delete, MM catch can, IWI 18% lower, DSX flex sensor, etc….I am not doing headers for now…
Any idea how well this setup will work and what kind of power numbers I’m looking at?
Old Jun 25, 2025 | 09:50 AM
R3DRUM's Avatar
R3DRUM
I would do a low side over headwork to really take advantage of those mods - will cost about the same or less and you will get a lot more power out of it than heads. These heads are pretty good as they are, low side on a 16, not so much.... JMHO
Old Jun 25, 2025 | 10:03 AM
Shawnm32's Avatar
Shawnm32
only head work is just upgrading springs, etc. For the cam..no porting etc….
Old Jun 25, 2025 | 11:37 AM
xxDevilDogxx's Avatar
xxDevilDogxx
Port the blower , skip the head work , skip the 103 throttle body , get 2" headers , and low side , ( right pulley setup ) You should see mid to high 700s maybe 800s if you have meth / supporting fuel . Fuel is the Achilles heel of these cars .My car made 740whp E60 ran a 6.1 60-130, no meth with port injection , no cam or dod delete. If you get port injection skip the Flex fuel kit , just buy the sensor and wire it in. I run the DSX Atlas Port its awesome , TH PSI makes a setup too but uses a separate tuning software .
Old Jun 25, 2025 | 12:50 PM
EXCUSES.Z06's Avatar
EXCUSES.Z06
Do the headers now, we just finished up a kong ported blower (not X) car (2.5) pulley with a stage 1 BTR cam, cold air, lower - Made upper 600s on e30.
Probably be back for headers and a 2.3 soon.
Old Jun 25, 2025 | 01:07 PM
Shawnm32's Avatar
Shawnm32
Default Reply
any videos of idle or anything? Interested how the chop was on a stage 1 cam….
Old Jun 25, 2025 | 01:13 PM
EXCUSES.Z06
See below
View this post on Instagram
Old Jun 26, 2025 | 10:52 AM
R3DRUM's Avatar
R3DRUM
Man I did not realize the stage 1 sounded that nasty - Ryne @ BRC recommended that to me and after hearing this I think I definitely will go that route. Also, for your business needs, I don't think there is a better LTX calibrator if you wanted to give him a try on something, he is in magnolia - do what you will with that information.
Gig em
Old Jun 26, 2025 | 10:54 AM
EXCUSES.Z06
Gig em
I've spoken with him actually, Lorenz @ LSX will always be my #1 when it comes to LS/LT tuning , he's been tuning for me and my friends for a long time. Ryne would def be someone I would work with though.
Old Jun 26, 2025 | 11:37 AM
R3DRUM's Avatar
R3DRUM
Yeah I've just had the pleasure of working with him on my 19 and he is the real deal; glad he is in the land of the free now! lol
Old Jun 26, 2025 | 01:10 PM
revo1059's Avatar
revo1059
St. Jude Donor '11
Whats the recommendation for reliably upgrading the low side?
Old Jun 26, 2025 | 01:29 PM
xxDevilDogxx
the DSX kit
Old Jun 26, 2025 | 02:10 PM
R3DRUM's Avatar
R3DRUM
Originally Posted by xxDevilDogxx
the DSX kit
Or a Fore drop in module if you want to get spicy...
Old Jun 27, 2025 | 09:36 AM
xxDevilDogxx
also DSX is releasing a dual pump setup for the C7 . Check their Facebook they just posted a couple videos .
Old Jun 29, 2025 | 12:30 PM
R3DRUM's Avatar
R3DRUM
Holy **** my prayers have been answered! Hopefully don’t have the issues like katech - is it bucketed? Normal standard pumps that usually come with these kits or better ones?
Old Jun 29, 2025 | 12:52 PM
xxDevilDogxx
Bucketed brushless pumps and controllers all plug and play. All the stuff they put out is top notch i doubt the will release anything with issue.
Old Jun 29, 2025 | 01:05 PM
Internets_Ninja's Avatar
Internets_Ninja
You're leaving a lot on the table by not installing headers. Also, I wouldn't go with an 18% lower unless you're running meth or upgrading your injectors. You wont have enough spray time to use high E content and the blower will heat up stupid fast. I would be less aggressive on the pulley setup otherwise.
Old Jun 29, 2025 | 05:35 PM
crewchief25's Avatar
crewchief25
Default BTR stage 1 Sc cam
BTR Stage 1 217/239 639/639
File Type: mov
To C7Z06 mods
