Performance Traction Management Not Working
Old Jan 7, 2026 | 08:02 PM
Whisky's Avatar
Whisky
Default Performance Traction Management Not Working
Hi Ladies and Gents,
2017 Z06 A8
I've used launch control and performance traction management many times before and was able to get it to work.
It's been about a year since I tried but went out for a bit of spirited driving this evening and could not get the PTM to work as it blew the rear tires off in about every setting (I didn't try wet).
I've done the drill many times before, car stopped, steering wheel straight, rotate mode button to TR, press twice, select PTM mode in DIC (usually sport 1), press mode button to confirm and it was all set.
Then, stepped hard on brake, floored gas and when the rpm settled, let off the brake and away we would go only this time it spun the tires no matter what mode it was in when I let off the brake.
Thoughts?
Old Jan 7, 2026 | 09:32 PM
Dave McDufford's Avatar
Dave McDufford
Active Streak: 90 Days
I think your "press mode button to confirm" turns it off. At the track I just turn to the mode I want and go.
Old Jan 8, 2026 | 03:13 AM
Bill Dearborn's Avatar
Bill Dearborn
I agree. After pushing the mode button twice to get into the PTM settings you don't touch the center button again. Pushing the button after you have made your selection moves the setting out of PTM mode.
Bill
Old Jan 8, 2026 | 05:01 PM
Whisky's Avatar
Whisky
Well, I went out again today and no dice. Once I had the mode I wanted, I just left it there, didn't push any buttons and even in "Wet" mode it still l blew the tires off.
I even got a new battery as this one was doing some funny things like draining itself when I disconnected it to work on the car a few times.
Old Jan 9, 2026 | 08:17 PM
Exia's Avatar
Exia
Its pretty normal to blow the tires off?
Are you trying to do launch control?
You don't need to select with the mode selector. Once the PTM modes come up in the DIC, simply turn the dial to the one you want and your good, no need to press on the mode selector.
If the tires still spin that doesn't mean its not working, its still a front engine RWD car, PTM doesn't make it impossible to "blow the tires off". Lots of factors go into a launch, tire age and tread depth, temps etc. Its not a drama free ride.
What exactly are you trying to do in PTM mode?
Old Jan 10, 2026 | 03:20 PM
Whisky's Avatar
Whisky
Yes, I'm using launch control, that part works. When using launch control and PTM in conjunction with each other the tires should have minimal slip. I've done this many times before including drag strip passes. It's how I got a 1.72 60' time on stock run flats and yes, it was drama free, just keep your foot to the floor and steer.
EDIT: I went out tonight and found out traction control is not working in any mode. I can light the tires without any nannies kicking on which I could never do before.
Old Jan 23, 2026 | 02:29 AM
Bill Dearborn
Traction Control and the more sophisticated PTM feature are both controlled by the EBCM. Do you have any lights like the traction/stability control indicators that have turned on?.
Bill
Old Jan 23, 2026 | 07:42 AM
Whisky's Avatar
Whisky
Bill
Yes, when I push the console button twice the light that shows traction control is off, comes on. When I use launch control and the tries break loose it starts to flash.
I've had it diagnosed at the local chevy dealer, and they say nothing is wrong with it. General consensus is that the tires (5 yrs old, 15K miles) have head cycled and gotten hard/lost grip.
The traction control does intervene but not before I blow the tires off. It never used to do this. I have new tires coming (Continental Extreme 02s) so we will see what happens.
Thanks.
Old Jan 24, 2026 | 12:24 PM
Track's Avatar
Track
Now I'm confused. TC is always on, so having the light on before punching it would mean it is off. With mine the flashing shows it is engaging.
One thing I screwed up when the car was new is that I would feel the wheel spin and get off the gas...which then confuses the TC and the wheels would spin continuously. To work you have to keep the throttle down, so it can do the managing.
I suppose low tire traction could reduce the TC below its working limit, so it cannot reduce the power enough to prevent the spin?! I would suggest checking for unanunciated codes...but I would assume the dealer did that.
Old Jan 25, 2026 | 08:21 AM
Whisky's Avatar
Whisky
Assuming you have a Z06, turn the center console **** until "Track" setting, then push the button in the center twice. You will see the traction control light come on in the dash. This allows the car to enter PTM (performance traction management). When I first got the car with 11K miles on it, I could use launch control in PTM mode and there was no spin at all. Now it blows the tires off before traction control steps in. I ordered tires from Tire Rack, which is another story in of itself, what a fiasco. Beware of using one of their "preferred" installers.
Old Jan 25, 2026 | 11:23 AM
Track's Avatar
Track
I'm running an M7. It never hits without some spin...
Still, interesting they reverse the meaning of the light, sometimes on and sometimes off, to indicate active TC!?!
Old Jan 26, 2026 | 07:18 AM
Whisky's Avatar
Whisky
Exactly! Very confusing.
Old Feb 15, 2026 | 05:10 PM
Bill Dearborn
The Traction Control Light should be on when the Drive Mode is set to Track/Sport1, Track Sport 2 or Track/Race. TC is turned off in those modes, so you only have Performance Traction Management, which is a much more sophisticated form of Traction Control that uses the eDiff to ensure torque is delivered to the non-slipping wheel.
Active Handling is off in Track/Sport 2 and Track/Race Modes, while throttle dampening is turned off in Track/Race modes.
Throttle dampening doesn't limit full power; it only limits how fast it can be applied and removed, discouraging the tendency to use the throttle pedal as an on/off switch.
Bill
Old Feb 16, 2026 | 08:41 AM
Whisky's Avatar
Whisky
Bill
Yes, I was able to cut 1.72 60' times at the dragstrip using PTM set to Track/Sport 1.
I took it to the local chevy dealer, and they said PTM was operating.
The consensus was that I needed new ties as the stock Continental run flats had probably been heat cycled. I always thought that the PTM/Traction control should work no matter what the condition of the tires?
I have since gotten new tires and have yet had a chance to test them out.
Thanks for replying. I'll let you know how it turns out.
Old Feb 17, 2026 | 08:22 PM
Whisky's Avatar
Whisky
I put a new set of Continental Extreme Sport 02s on it and it seemed to cure the issue so it was the tires all along.
I don't know if these are quite as sticky as the Michelin Pilot Sport ZPs as I'm getting a little slip and I can hear the throttle dampening which I didn't used to hear.
I haven't done any 0-60 tests yet but when I do I'll check back in and let you know the results vs the Michelins.
Thanks for all your input!
Marc
To Performance Traction Management Not Working
