Lt4 injectors
Old Apr 24, 2026 | 06:48 PM
coilovergto's Avatar
coilovergto
Default Lt4 injectors
12701126
12668397
12668396
What can you guys tell me about these lt4 injector part numbers? High flow, nominal flow, low flow? Have 4 of all part numbers listed. Ok to run together?
Old Apr 25, 2026 | 07:08 PM
TxLefty's Avatar
TxLefty
Rock Auto has them labeled a GM OE nominal flow.
2016 CHEVROLET CORVETTE 6.2L V8 Supercharged Fuel Injector | RockAuto
I make no recommendations, but here is the information that I found.
Old May 3, 2026 | 06:04 PM
Lux's Avatar
Lux
The injectors all have varying levels of flow. low flow means they flow slightly less than spec, nominal flow at spec, and high flow a tiny bit over spec.
Its such a small amount it doesn't matter as long as you run all 8 of the same flow type as your fuel trims will correct the difference. If you run mismatched the ecu isn't able to correct on a per cylinder bases.
To Lt4 injectors
