ZR1 8 speed not 10 speed-why?
Does anybody know why the new 2018 Zr1 is coming with the old 8 speed automatic and not the 10 speed? All I can assume is the 10 speed can't handle the torque and is going to the more robust 8 speed?
The following 3 users liked this post by John Ulrich:
I bet you're right
johnglenntwo (11-14-2017)
Too much gear! ;)
They would had to have pulley down the LT5, which, would hurt marketing!
Just like a ZO6 A8 limp mode at The Ring would have!
↑ Then why tarnish the ZR1 namesake by attaching it to the C7 which has garnered something of a negative rep with the A8. For just a few thousand cars a year, it could have waited and instead, bump the HP of the Z06 by a few to keep its interest up before the C8.
Who cares about the ZR1 name? It's just a name, which is not all that special, particularly when the C7 version puts all previous ones to shame. They trotted out the ZR1 name w/ the C3, C4 and the C6 gens late in their lives. By your definition, all ZR1s should be considered "tarnished," as more power on an aging platform w/ a few other tweaks.
ZR1 has historically been a marketing ploy to pump a little more life into Corvettes late in their run to generate a little new excitement about aging models. It's always worked because many customers fall for new model name games. They could have put wider fender panels, wheels, and bigger brakes on the Z51 to distinguish it from the base, but for marketing purposes it was better to bill that incarnation as an entirely new model (GS). The new model name game is working again, but there is always something much better on the horizon.
GM could have done the same here instead of watering down the name ZR1 by associating it to the C7 generation.
At least in the case of the ZR1, the price tag includes a bump in HP and other performance enhancements. The GS seems like a watered down car, not just a watered down name. Yes I know, the GS has its loyal following but for every article boasting it, I can find one saying it needs "just a little more HP".
when the new zr1 can go out and take the FIA endurance record which currently sits at 201 ave, it has earned the legendary status
with a top end of 210, and a few tweaks to add more hp and reduce drag, the car could get up over 215 or so which would just make it fast enough.
Come on GM, I'm ready, let's do this thing!
It's only right to prove the meddle of the car and make the new king worthy to the throne.
Go ahead, you’ve got the stage — tell us all exactly how the entire C7 generation is such a failure that GM shouldn’t “tarnish” the ZR1 model by association.
It's always been used for just a few cars, the fewest being 500 or so C3s. It's never been used to introduce a new generation, which is what you seemed to be implying should happen to avoid a "tarnish" on the name by using it for a C7 model. That was utter nonsense.
Received 3,809 Likes
"Ask Tadge" Producer
GM's 10 speed auto transmission is not a modular unit like the 8 speed. The bellhousing is part of the main case casting. It was jointly developed by GM and Ford as a light truck and passenger transmission. Due the size of the case, length and bellhousing size, it will not fit in the C7 rear tunnel that houses the transmission.
TREMEC is currently developing a modular auto transmission which may be sourced by GM.
http://media.gm.com/media/us/en/gm/h...0speed-gm.html
http://www.tremec.com/menu.php?m=155
