ZR1 un-tunable?
#241
Not a lot (I do have computer patents) but the point I was making was that obviously GM can alter the coding so there is software at GM that will do the job and with China hacking into everything possible I was making a joke about China probably could have the software to alter the Corvette's programing
#244
Yea you can buy a lt5 with a different ecu from GM.
#245
evolmotorsprt (01-09-2019)
#247
Pro Mechanic
Pro Mechanic
#249
Received 1,817 Likes
I wonder why they used larger Direct Injectors, and didn't use the port injectors at all? Was it so they could use one of the older ECM's which they could get into and tune?
#250
Ben@WeaponX (01-09-2019)
#252
St. Jude Donor '14
Yea, has nothing at all to do with tuning the E99. LT5 blower on an LT4 bottom end since the majority of the hardware is the same, no port injection, FIC's +30% injectors and Uwe's Xtreme DI pump system to fuel 1000 crank HP.
#257
#260
