C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
ZR1 2019 Corvette 10.12 (502 miles)
Old 04-17-2018, 01:31 PM
  #41
BlueSteel07
Cruising
BlueSteel07's Avatar
This run is very close to what we've seen from Dodge Demons in +500 DA with very similar trap speed. I've seen a couple Demons run 9.9x-10.1x at 136 mph in similar conditions. I wonder if the ZR1 will get close to 140 mph in Mine shaft air?
Old 04-17-2018, 01:48 PM
  #42
Dave Schotz
Dave Schotz's Avatar
Great Run!
What size rear drag radial?
Nice to see 135 MPH... and I believe with the Auto... we'll see 1.50 60' or better!
Best Regards,
Dave
Old 04-17-2018, 01:56 PM
  #43
racerns
racerns's Avatar
Originally Posted by charles7970
1.5ish 60ft is insane! Plus the DA was perfect.. I think its as good as it gets. Unless you can hit a 1.3 60 with a better tire..
Actually a 1.57 60' time is not particularly insane for a drag radial. This same driver has pulled a 1.48 60ft with a drag radial in his stock C7 Z06 A8. Stock A8 Z06s on stock tires have pulled low 1.6x 60' times. There is more to be had with even better DA and improved 60' which he has proven he can do. A high 1.3 60' time (probably not going to happen on a stock stall) could have resulted in something like a 9.7 et.
charles7970 (04-17-2018)
Old 04-17-2018, 02:21 PM
  #44
charles7970
charles7970's Avatar
Yea i agree I'm also wondering how strong the rear's are in this model
Old 04-17-2018, 03:33 PM
  #45
3 Z06ZR1
3 Z06ZR1's Avatar
Not trying to be bad news! BUT Compared to the OP's Z06 stock with tire run on the fast list!
This car is not much faster even slower trap speed! https://www.corvetteforum.com/forums...fast-list.html
Old 04-17-2018, 03:44 PM
  #46
Dr.Ron
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Nice! Looked easy. No apparent traction issues whatsoever.
It seemed like it could take a harder launch. Did you try that at all?
Ron
Old 04-17-2018, 03:53 PM
  #47
UBNZO6D
UBNZO6D's Avatar
You are a killjoy and have a habit of killing someone else's joy...That was his first run just letting the world know about possibilities, not his best run after seat time...Lighten up.
Greg
RoketRdr (04-18-2018)
Old 04-17-2018, 03:54 PM
  #48
JMB
JMB's Avatar
It's never a good comparison when looking at "hero" runs in minus DA.....but if you insist on comparing, let's assume he matches his 1.48 60' time from the hero run with the Z06.....his 10.12 turns into a 9.98 in +450 DA....now that is BEYOND impressive
The following 2 users liked this post by JMB:
3 Z06ZR1 (04-17-2018), UBNZO6D (04-17-2018)
Old 04-17-2018, 04:00 PM
  #49
racerns
racerns's Avatar
That run was done in negative da, skinnies on the front, full .1 60' time better, and not his first time ever taking the car down the track. Similar conditions, setup, and launch the ZR1 is running 9.8s.
The fact that he was still faster with a slower 60' and lower trap speaks volumes.
The following 2 users liked this post by racerns:
Old 04-17-2018, 04:15 PM
  #50
3 Z06ZR1
3 Z06ZR1's Avatar
the Slips can be misleading from different factors
like the faster 60ft on the Z06 slip!
The new car is faster than it shows head to head it would be obvious!
Old 04-17-2018, 04:26 PM
  #51
3 Z06ZR1
3 Z06ZR1's Avatar
Greg
Good advice for yourself! Was talking about just those runs. That Z06 time is a world record I would say! We know the ZR1
is faster by a wider margin than on those slips. 9.xx is coming
Old 04-17-2018, 05:11 PM
  #52
Palantirion
Palantirion's Avatar
Originally Posted by Ruz
Not bagging on the OP's post, because it is a heck of a run...but you are trying to rip the Demon which is cheaper, by saying it is "only" a half-second quicker in the 1/4??
The two cars are in no way direct competitors...
-No, not at all. But a little. More like friendly ball busting. My expression's motivation was surprise that a perfectly well-rounded sports car could even be even close to the same league as a purpose-built drag car is silly - in the best possible way.
Old 04-17-2018, 05:15 PM
  #53
Zip Corvettes
Platinum Supporting Vendor
Zip Corvettes's Avatar
This was the first and second pass. It will take some time to get used to the car and launching it. It is going to go faster.
Old 04-17-2018, 05:53 PM
  #54
moose.b3
moose.b3's Avatar
Ok, that was great. Now it's time for a 100 octane run!
Old 04-17-2018, 05:58 PM
  #55
OnPoint
The Consigliere
Support Corvetteforum!
OnPoint's Avatar
Received 5,447 Likes on 2,272 Posts
OP - nice run. Thanks for posting. You'll have the stock ZR in the 9s in no time.
Rig sounds pretty decent running out also.
Old 04-17-2018, 06:25 PM
  #56
Ted P
Ted P's Avatar
would be more impressive if stock. waiting to see more of those runs. should beat GM time of 10.6
Old 04-17-2018, 06:29 PM
  #57
Mopar Jimmy
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Fantastic results Farmer Z, especially for the first time out with that new King of the Hill of yours!
To ZR1 2019 Corvette 10.12 (502 miles)
Old 04-17-2018, 08:32 PM
  #58
cerino2000
cerino2000's Avatar
Hell of a run! Nice job putting it to the ground! I am curious as to what the other runs were. Thing about the demon and hellcat is they are very consistent. Even sub crappy drivers will regularly run excellent times with a good launch. Vs my Corvettes my Hellcats and my Demon typically never got much slower. Always within a 10th even when hot-lapping. What were the ZR1’s other times/traps? Sounded good too!
Old 04-17-2018, 09:33 PM
  #59
johnglenntwo
johnglenntwo's Avatar
Default Demon!
'YOU'RE NOT SO BAD!'
Old 04-17-2018, 10:08 PM
  #60
jonnyc
jonnyc's Avatar
wait until people can start tuning them.a good tune,well prep track,and -da i could see 9.6-9.7 on dr's
Quick Reply: ZR1 2019 Corvette 10.12 (502 miles)
