C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
10.2 Stock ZR1
Old 04-21-2018, 12:55 PM
Snorman
Scraping the splitter.
Support Corvetteforum!
Snorman's Avatar
Received 1,028 Likes on 486 Posts
St. Jude Donor '13-'14-'15
Originally Posted by Walter Raulerson
Then they bitch if the engine blows
How do you know somebody doesn't have a ZR1 with adequate break in miles on it?
How many miles are on the car that apparently ran a 10.2?
Why do you think the engine will "blow" if it doesn't have enough miles on it?
The break in is primarily for the clutch (M7 cars) and differential. Once the engine is running for a short period, there's nothing to "break in". Change the oil and it's good to go. This isn't the 1960's.
S.
Snorman is offline
The following 3 users liked this post by Snorman:
Detoxx03 (04-22-2018), RoketRdr (04-21-2018), zhopper05 (04-27-2018)
Old 04-22-2018, 07:39 PM
Walter Raulerson
Walter Raulerson's Avatar
S.
One reason is that SOME post "just got my ZR1" then on You Tube they are drag racing. One guy raced his at 495 miles and said so .Also if the engine doesn't need to be 'BROKEN IN" why does GM say to do it? Is this to protect GM? If it wasn't necessary why wouldn't they say "hey once you get your car just go drive the crap out of it don't worry about how fast you go" Doesn't it tell the new owner how to break the brakes in also?
Walter Raulerson is offline
Old 04-22-2018, 08:01 PM
Z06 1of38
Z06 1of38's Avatar
Is it hard policing the world?
Z06 1of38 is offline
Old 04-22-2018, 08:36 PM
keagan
keagan's Avatar
Fran??
keagan is offline
Old 04-23-2018, 10:44 AM
Rkreigh
Rkreigh's Avatar
without drag radials 755 hp will be a smoke screen even at the digs.
the z06 with 650 was traction limited, another 105 isn't going to make it better.
10.6 on street tires is impressive, and 10.2 on drag radials is pretty good.
I agree with above, tranny and diff take more breakin than the engine. the new engines are happy pretty quickly and do most of the break in within the first hour of running.
time to go to MIR and see for myself!
Rkreigh is offline
The following 2 users liked this post by Rkreigh:
keagan (04-23-2018), RoketRdr (04-23-2018)
Old 04-23-2018, 04:38 PM
Walter Raulerson
I would comment on a certain situation but politics are supposed to be off limits
Old 04-24-2018, 09:08 PM
70Apollostaged
70Apollostaged's Avatar
For the life of me I cant understand why some people are so......loony. In this ridiculous argument over "stock" or "not stock" because of a set of tires I've noticed the racers of the group can make a clear distinction that tires are traction aids only. No HP was added nor a tune. The car is still stock, but on sticky tires. Racers know that "not stock" means the MECHANICALS or TUNING of the car was altered.. Only people that dont race would even make the asinine claim the car isnt stock due to tires.
70Apollostaged is offline
The following 4 users liked this post by 70Apollostaged:
BJ67 (05-03-2018), Kappa (04-27-2018), RoketRdr (04-25-2018), The Rock1 (04-25-2018)
Old 04-24-2018, 11:45 PM
racerns
racerns's Avatar
I don't know, maybe some people are interested in what car runs as it was equipped from the factory. Tires can reduce the et by 1/4 sec or more. There is a reason we have separate categories on our fast lists.
racerns is offline
The following 3 users liked this post by racerns:
blb078 (04-27-2018), furiousox (04-27-2018), RoketRdr (04-25-2018)
Old 04-25-2018, 04:00 AM
3 Z06ZR1
3 Z06ZR1's Avatar
Yep ! Forget the street tires! Mine was horrible even leaving easy still spun till past the 330 mark and the car is a lot faster but is slower at the track with 775hp give a take a few. But the track was gone 500 cars were running several events.
3 Z06ZR1 is offline
Old 04-27-2018, 07:40 AM
Stephen02Z06
Stephen02Z06's Avatar
it was wfarmer.z trying to beat his 10.12 in negative DA. How do I know? I was there and watched the runs at MIR and I know Will. The car couldn't back up the 10.12 from Richmond Dragway, but it wasn't for lack of trying. He was having some issues with tire shake and stability during the passes. He was not happy with the new set of rear tires he had just installed on the exact same wheels as the previous 10.12 pass. 10.2@134 was his best due to these tire issues. He was able to beat his best 60' time as I read the scoreboard and saw a 1.53 on one of his passes. No worries...he will resolve this issue and try again soon.
Stephen02Z06 is offline
The following 3 users liked this post by Stephen02Z06:
keagan (04-27-2018), PRE-Z06 (04-27-2018), tail_lights (05-01-2018)
Old 04-27-2018, 07:47 AM
Stephen02Z06
pic from MIR. My ZL1 in the background. wfarmer.z in the drivers seat.
Old 04-27-2018, 09:47 AM
keagan
keagan's Avatar
Thanks for posting! Wonder why the driver didn’t post but now I know!
keagan is offline
Old 04-27-2018, 09:51 AM
  #33
zhopper05
zhopper05's Avatar
2015 C7 of Year Finalist
Originally Posted by StingRayJack
Very exciting!! I am so looking forward to running mine against the exotics.... come on with my order GM... however I think the allocations for Galveston and Siberia will be the last two out of the doors at Bowling Green....
Jack - who do you have yours ordered through?
zhopper05 is offline
Old 04-27-2018, 10:48 AM
  #34
EV2DEMON
EV2DEMON's Avatar
Please explain the mechanics behind an engine failure that is directly caused by low mileage. I don't mean "because GM says so". I'd like you to describe the failure mode that is a direct result of low mileage.
Anxious to hear your response.
EV2DEMON is offline
Old 04-27-2018, 11:57 AM
  #35
Mike Jesse
Mike Jesse's Avatar
Look at the front wheel, that's probably a skinnie.
No worries here, wheel/tire swap is fine with me.
Mike Jesse is online now
Old 04-27-2018, 01:18 PM
  #36
Stephen02Z06
It is a CCW drag pack. The fronts are definitely narrower than stock but not exactly a "skinny".
Old 04-27-2018, 01:22 PM
  #37
427Z0SX
427Z0SX's Avatar
Originally Posted by keagan
Nope! Stock means well, stock. Bone stock means very stock! You can’t get No stocker than that
And then there's the nebulous "showroom stock", just to add to the confusion,
427Z0SX is offline
keagan (04-27-2018)
To 10.2 Stock ZR1
Old 04-27-2018, 02:21 PM
  #38
meadowz06
meadowz06's Avatar
St. Jude Donor '09 and '13
BIngo. Drag tires don’t make a car STOCK!
meadowz06 is offline
blb078 (04-27-2018)
Old 04-27-2018, 02:22 PM
  #39
meadowz06
meadowz06's Avatar
Originally Posted by johnglenntwo
Factory Warranty, and simple Bolt-on!
A rear drag slick is not a simple bolt on. And that makes it modified!
Old 04-27-2018, 04:13 PM
  #40
blb078
blb078's Avatar
I race and if I see a car without factory tires then it's not stock. Like this car, not that I care but it is what it is. Something on the car is being altered/changed in order to make it go faster. Doesn't matter if it's mechanical, tuning, tires, or reducing weight in some way. The simple fact is if you change the way the car came off the factory line to make it go faster then it's not a stock car. So this car is not "bone stock" as the OP claimed.
blb078 is offline
Quick Reply: 10.2 Stock ZR1
