Front inner fender part #
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Anyone with access to GM's parts catalog/computer, can you see if you can provide me the part numbers for the ZR1 front inner fenders (driver/passenger) with the vents into the wheel well? If the price isn't exorbitant, I would like to see if these can be modified to work on a C7Z with aftermarket cooling.
Thanks!
Thanks!
Thanks!
Thanks!
Sort of my thought process as well. Figured I would start big and go from there, assuming someone can look the part number up. It does almost appear as though the liner is molded to fit the vent but we'll see. Currently using a wire mesh that is riveted in place but this would be a cleaner solution.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
Eric,
Are you talking about the plastic fender liner or the actual inner fender panel (bonded fiberglass panel)?
If just wanting the plastic liners, part numbers are:
Left: 84388705
Right: 84388706
RICH
Left: 84388705
Right: 84388706
RICH
Thanks Rich! Very much appreciated!
It's crazy but I have took the passenger side liner out of mine this morning. Trying to get all the air out of the intercooler tank. The hoses are so short it's hard to move the tank enough to get it all out.
Any way to shed more light on this? I just did a track day with the new 315/345 hoosiers and I am rubbing thru the fender liners. The front wheel rubbed thru the liner and started rubbing the plastic panel that is the same "tub" that can be felt from the engine bay. The rears are just rubbing the cloth liners. Do you have part numbers for all that? Obviously, this is for the c7 zr1.
I think I may be a bit too low possibly. While stance is good, the stock shocks in track mode are not stiff enough to prevent this.
THank you
THank you
THank you
What size Hoosiers are you running? How much did you lower the car (front and rear)?
