C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Tool to adjust wing angle
Old 03-13-2019, 11:28 AM
  #41
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
Originally Posted by MustOBeenYellow2015Z
This is how I would do it:
-Loosen the back bolts (rear of car) & take out the front bolts ( front of car)
-The front bolt holes of the brackets is some what slotted
-Drop the wing in the bottom holes for more angle on your wing & top for less angle
When I get back home I can take photo's of the brackets for more clarity, if youd like.
I believe it's the other way around. Loosen the front bolts so the wing can pivot but you need to remove the rear bolts then raise or lower the wing. There are two fixed positions so it's not truly slotted. Make sure you note which way the bolts go back in as one half has a square surface like a carriage bolt.
MustOBeenYellow2015Z (03-13-2019)
Old 03-13-2019, 11:41 AM
  #42
MustOBeenYellow2015Z's Avatar
, thanks..
Old 03-13-2019, 02:02 PM
  #43
Sooo..
I did indeed misguide you & had it backwards, sorry!
Left side bracket..
Slotted rear bolt hole..
So the wing will “pivot” on the front bolt hole & adjust with the rear bolt hole.
So the wing will “pivot” on the front bolt hole & adjust up or down with the rear bolt hole. Hope this clears everything up, lol
Palantirion (03-14-2019)
Quick Reply: Tool to adjust wing angle
