Summit Point Track Day Report
#61
Received 3,805 Likes
"Ask Tadge" Producer
For what little it may be worth: I solve the seat belt light/alarm issue by just running the belt behind the seat and latching it. Done.
#62
Track Rat
I ran the past two days at the Glen with Schroth 4 pt Profi ASMs, BK bar, comp seats, bk lap belt mount kit, and seat belt eliminator plug (no chime or light). Very happy with this setup. Highly recommend if staying with stock seat.
I'll be at NCM VIR if you want to check it out.
My reason for thinking I'll run the 3-points over top is more as a failsafe than because of the seatbelt alarm. I'm still concerned about the harness routing not being correct with the stock seats and whether the setup will perform as designed. With the 3-points also fastened it gives me an extra measure should something go wrong with the harnesses.
#63
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
Sean we all think its time for you to change your avatar here. Sorry but the old Z just doesn't work any more
BTW, I bought the BK eyes for the clip on harness ends at the seat years ago. Pull the seat and simply bolt them to the existing seat\pivot bolt then twist them so their easy to access. Out of the way when not in use but a bit of a pia to snap the harness on and off. If I remember all for under 50!
#65
Mike texted me Monday afternoon and said the 12-17-2017 firmware was working on the 2018+ cars, you just might need to drive it a couple of miles the first time before the PTM modes work. I flashed the firmware on the same unit I had in my 2017, installed it sitting in the paddock, and it just worked without having to do anything.
I have waited for ever to install it in my 2018 Z06, bought it in march.
And now you say it works with firmware from dec 17th , 2017 ????
I PM to DSC, he asked me to get back to him this week, haven't heard anything... really hope it can be tested ... going for a 4000 mile road trip down Europe and SPA, Nurburgring and Salzburgring is on the menu....
How about DSC shocks... how much improvement is it versus stock shocks ?
is it just on track you will notice a difference ?
tia
edit: Should read the whole post before asking , lets see what you and DSC can come up with so i can use my controller....
Q on shocks still remain :-)
Rune
#67
Track Rat
Now that we're back on topic I wanted to offer a couple more observations from my first track outing with the ZR1.
Like the C7 Z06s I had before, the car pops out of 5th gear under heavy braking. I guess I'll be ordering up another MGW shifter as that fixed the problem on the Z06.
While the trans temps got hot I do not see the spray of trans fluid under the car like I saw with the Z06. Perhaps they fixed the issue with the vent or the fluid. I still plan on replacing the stock fluid with Redline D4 after VIR.
No lift shift works substantially better on the ZR1 than on the Z06. I never once got the balk or throttle cut that typically happened with the Z06.
All things considered, the pad life wasn't horrible but it wasn't great either. I only drove 2 1/2 hours this week which for me is on the low side but is about what a typical 2-day HPDE has. My pads have 11.5mm of thickness after the event and 6mm of that is the backing plate. I believe the stock pad thickness when new is 17.5mm so I burned through half the pad in 2 1/2 hours on track. Remember that pads tend to wear more quickly as they get thinner and you can't run them to the backing the plates so I'd figure 4 hours of track time out of a set of pads.
#68
Sean, what's your shifting style under braking? As I mainly run Sebring, my top speed is 152mph down the back straight which is the limiter in 4th. I never go in 5th to even experience the popping out of gear. However, my sense is that I'd be reaching down to downshift into 4th pretty quickly and early in the braking event so perhaps I'd never experience it? Heavy braking in 5th seems like a very short moment in time. Any in-car video of it happening?
#69
Sean, thanks for the update.
Regarding the Redline D4 fluid, did you use it in your Z06?
Did it improve shifting and or was it for the temperature issue?
#70
Great to hear your reports.
My Z06 was popping out of 5th again this week at the track. I can downshift to 4th to prevent it, but that messes with my brake timing. I have an MGW sitting here, but waiting for dealer to fix other issues before I install it.
Interesting you didn't loose any tans fluid yet. I am thinking my Z06 was overfilled from the factory, but it was my 3rd track day when it lost fluid. Did you loose any fluid after you started running Redline?
#71
Track Rat
I haven't run the redline before. I just ran the stock fluid in the 2017 and ran Amsoil in the 2015 but it still puked fluid.
#72
Track Rat
#73
Do we think the trans belching is from expansion? Not sure any will differ that much from the others.
Poor-sha (06-17-2018)
#74
I think the benefit of different transmission oils is very subjective and probably mostly mental...but I've now tried OEM, redline and amsoil in the Z06. I like the OEM juice the best and Redline the least. The Redline has shitty gear shifts and feel. No explanation for it as Redline was great in the TR-6060 in my previous CTSV.
As for Fluid Belching: I do believe it is temperature related (expansion), if you can keep the fluid temps cool, you'll have less expansion and no belching. It seems the ZR1 is doing better on temps, which would correlate to not resulting in overflowing.
Keep us updated on how you like the Redline fluid once you change.
Best Regards,
Dave
#75
Poor-sha had 307F trans oil temp and no belch. My Z06 belched around 240F.
#76
Yes, it appears it was overfilled because after the car sat for two weeks the fluid was still high when I prepped for the next track day. What temp would you normally expect it to loose some fluid?
Was hoping an oil change to Redline D4 and a little MTL would help with shift smoothness and stability. Made my TR6060 in the ZL1 feel better.
#78
If/When I decide to get a ZR1, I'll probably stick with the OEM trans fluid, and change it regularly (if seeing temps in the 250+ range).
Will be reading/watching as others experiment for sure.
Best Regards,
Dave
#79
Forgive me if some have heard this. I discussed our 15 M7 trans with an employee acquaintance of Tremec a few years back. He understands the track duty well and suggested to use Mobile 1 ATF. Before changing it this spring finally mine was hard to slide into 2nd but never popped out of any gear. After the change and seems every time I shift now into second its super smooth as is all of them with the stock shifter. Never a puke or over heat of fluid either. If that happens I bet its a overfilled issue.
Spearfish.... 152 in 4th gear that great! Why can I only get 146 to 48 and the car then is bouncing off the limiter. Did you change a gear in the rear or trans? I have to shift into 5th to go over 150 although wish I didn't.
#80
