How to install end caps
This might be a dumb question but I am wondering if there are directions for installing the end caps.
I picked the car up from the Museum and the end caps weren't installed when I took delivery. Do I need to lift the car up to do it?
No need to lift the car up. I think all you need is a T-15 and a socket wrench for the lower screw under the splitter. I’m sure someone will chime in with more detail that I provided but long story short it’s a simple install.
There’s literally 4 screws to undo. But if you’re needing to have the performance intake done then so be it. But it’s a very simple installation.
The GM intake is involved, but the end caps are straight forward.
3 T15 and 1 7mm underneath. If the Z is not on a lift, make sure the 7mm is going verticle when putting them on. The cap lines up on install.
The following 3 users liked this post by Apex ZR1:
