TUNERZ STORE | DSC Sport v4 Controller C7 Corvette
When activating launch control, brake pedal pressed and quick gas pedal pump I get a message service suspension system. Is this what indicates launch control is active? Or do I have other issues? 19 Z06 A8
Former Vendor
Former Vendor
The hazazrd lights should also flash once to indicate launch is active if the sequence is done properly.
I'm confirming the "service suspension system" is part of the protocol. Can you provide the firmware version for your controller? I also sent you an email.
Former Vendor
Are you supposed to leave the cable there permanently so that its easier to access in the future? Whats the norm? I dont want to pull the wheel and liner everytime I need to change the mapping. Does Wifi work?
Former Vendor
I would suggest leaving the cable in place to avoid the nonsense of taking the wheel off. The wifi works but not as well. I would rather have a stable connection in case you needed to update firmware. Beyond zeroing shocks initially you probably aren't going to be using the cable much unless you plan on doing your own tuning.
Former Vendor
#34
C7 2.1 1-20-19 V4
#35
I am not going to mess with the cable. Rubber gasket there is put for a reason. When you drive this car in snow and ice, salt and all kinds of corrosion will end up anything thats not air tight. And eventually that stuff might short out. That short can cause havoc on the ECM and all electronics. Its OK for someone who drives their ZR1 6 months of the year in Florida weather but where I am, its quite different.
Do you have to completely remove the device to attach the USB cable? Can you not attach the cable without removing it from the fender?
#36
This is not as easy to install. There is no way to reach up there where the 10mm bolt is to remove the bracket without removing the wheel and the wheel liner. I dont know if ZR1 is more difficult but unless you have telescopic view of that little spot there its not happening. Even if you were to remove the bracket, how the hell are you supposed to align it back while reinstalling and what happens if you drop the bolt in there?
I love how aftermarket companies make stuff sound so good and easy but reality isnt so
#37
Former Vendor
Taking the wheel off is the utmost best option, period. The install is not as hard as it seems. I have faith you can do it without any issues.
#38
Former Vendor
#39
note: I sealed my cable with the rubber cap and compound to keep the elements out.
Tunerz Store (04-17-2019)
