World's first tuned C7 ZR1
Former Vendor
Up until Friday, only HPT and myself were able to edit a C7 ZR1.
ZR1 tune
It is being worked on.
We didn't try tuning a bone stock car. We threw mods on and were testing up to the last minute of release, so we didn't have time to dyno for the mods on the vehicle. The cost of entry to tune just is what it is. What you get out of it depends on the modifications.
That's cool someone finally figured it out. Hope you have money to burn to void the warranty on a $25K motor.
Garret (04-15-2019)
Former Vendor
We don't intend to really share any results until we have flex fuel 100% functional.
Why are there so many haters in here????
DSX - Congrats to you and HP Tuners!! I don't have a ZR1 but I think it's GREAT news those who want to have the option to tune. Results will come with some time.
Bigger supercharger - 2 fueling options so shouldn't run out of fuel should lead to some real gains stock and the ability to make pretty big power with minimal upgrades.
I'm excited to see what they will do - I think 1,000 rwhp will be a very real goal with good reliability.
Most of the people hating probably don’t even own a zr1.
This week we will see a few vendors finally get the ecu back from HP tuners and numbers will become public.
Patience grasshoppers. I am very curious about the flex fuel options and if it’s as easy as it was in the LT1&4. Flex fuel would be a MUST for me.
SpeedyD (04-16-2019)
Former Vendor
It will not be that easy. If you watch the quick clips we blasted at the end of our video, you'll see a super vague hint into what we have to do. The lingering question is whether or not it will require an OS mod.
#33
Bummer. Well I won’t even consider modding mine until flex fuel is an option. That’s the only way to truly take advantage off all those injectors ... keep up the good work guys. We appreciate you being pioneers.
#34
Might as well throw an eBay chip on it and call it good.
#35
Received 1,347 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
#36
#39
Car should pick up a lot of power....
Unlocking the tune is step 1, and as hard as it was, it may not be the hardest step... you still have step 2 of tuning it....
the tune on these is much more complicated than a normal c7z with a normal blower....
From what i understand, there is a controlled blow off valve in the lt5 blower always bleeding some air off on the stock tune, and the TB blade is not really ever fully open on stock tune, and on the aftermarket tune, that valve can now be kept closed and TB wide open.
This changes things of course... the amount of power that will be picked up is pretty large, ... but since the tune is complex, we need to stop calling it "a tune" like they are all the same where all that needs to be tweaked are the air fuel ratios and engine timing and tada! instead we need to realize, each tune may be a bit of a work of art, how they do it exactly compared to the next tuner, as when these valves open and close, and relative to each other... and also understand it will have different tunes for each gear...
most people probably dont want to make 1000lbs of torque when they take off in first gear... so the TB and BOV's need to control that, otherwise the driveline is going to snap somewhere. How much power in first gear?... how much power in second gear?... then there has to be the individual tune for each gear in the more traditional sense, once those TB and BOV's are set into place for each gear.
to say its a lot of trial and error, is an understatement. Human has to drive the car and see if they have grip in first or second gear etc... and/or also see if driveline breaks.
Meanwhile, that all assumes HP tuners gives the tuners access to all the tables the tuner needs after the tuner changes up the way the TB and BOV's work... my guess is, HP tuners wont have it all readily available at first... so then you will have a lot of back and forth between the tuners and HP, as they try to solve glitches since there was a table off limits that it turns out the tuner needed access to.
I write all of this so that people don't think "a tune" is a simple process or assume will be equal across the board with equal results tuner to tuner.
The LT5 should separate the men from the boys pretty quickly on creating good daily derivable tunes
This is cool for tuners however, once all the hard work is put in, they will be able to say to customers "go out and buy this part, put it on your car, take this canned tune, and you gain 300hp and torque"
parts may only be catless down-pipes and an exact recommended pulley swap, and a ported blower, and easily get a customer that 300hp.
Tuners wont necessarily brag its a canned tune, they may not sell it over the counter or over the internet as a canned tune... they will still likely want the car in their possession to make sure tune is behaving properly before they release it to the customer...
but it should be a copy and paste function for them, car to car, once they get it dialed in. Since there are 2 butterfly valves at play and GM never had them both at full tilt, i bet it will take time for tuners to really wrap their minds around how to do this optimally.
Keep in mind, there's a lot a tuner can now do wrong accidentally as well.
its going to be curious who releases 1000+hp zr1's first.
And then its going to be curious how the pioneer star tuner, protects his tune, and keeps another shop from getting its hands on his customer's tuned car, and copying that tune, and then them tweaking it slightly and calling it their own.
I did not see anything about the transmission and credits required to tune the tcm in the first posts, for the a8's... or is it the same as the z06 with HP tuners? I would think it would be zr1 encrypted as well, but perhaps not.
#40
Former Vendor
For these ECMs, you can't read the file out of it, so anything anybody flashes in can't be pulled back out. This is good for us, but potentially bad for customers that just need some minor thing changed.
TCMs are the same. $200 unlock process and four credits.
