AWE X-Pipe Center Section - C7 Corvette
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Built with Performance in mind the AWE X-Pipe delivers on all fronts.
Manufactured with the Highest Grade US Sourced T304L Stainless Steel,
and guaranteed not to trip a CEL Code. Deepen and Broaden the sound of
C7 Corvette with an AWE X-Pipe. Fitment for Stingray, Grand Sport and Z06/ZR1
C7 Corvette AWE X-Pipe
Regards
Chip
Any performance numbers? What is the weight? Trying to decide between this and Corsa...
ZR-1DUDE (07-10-2019)
Is it designed for the ZR1's exhaust flow and heat? Because GM proved that the Z06's exhaust was not entirely up to the LT5 task and ballooned.
- Yeah, follow the ZR1's development and one of the key changes was in the exhaust. The existing Z06 part ballooned out and failed from the LT5's heat and pressure. That was during track use, obviously. And many ZR1 owners track. If I were a supplier I would be concerned about liability supplying a part that wasn't tested under the conditions it might encounter with customers. As a consumer I would certainly not buy an aftermarket part that wasn't tested under (or designed for) conditions similar to factory part testing.
The liability would be with the manufacturer, not the supplier (vendor)
I checked with Corsa, Borla, Billy Boat, Magnaflow and they have seen no failures of the kind
you are speaking about. While I don't know about any specific testing on this piece, (specifically
for the ZR1) I can tell you that they use better material, and comparable or better manufacturing
techniques.
We've sent out about 8 of these in the last week or so for ZR1's and have had nothing but rave reviews.
I passed this info along to the appropriate individuals
Regards
Chip
I will take one. How soon can it ship?
Send me an invoice. Tjarion@gmail.com.
If you are going to clear it now - I'll hang out and get it keyed
Regards
Chip
Got my AWE xpipe yesterday and found the time today to install it. All I can say is WOW...Totally wakes up the sound of the car. Not really sure it added any power (maybe a couple HP), but holy **** does it sound better. When driving and decel the exhaust pops like crazy and sounds fantastic. For $450 this is a great mod to make the car sound great and free up some restriction.
Install was a breeze and overall the piece fit very well.
Video from stock exhaust flaps closed then I open them:
Video from after the install and initial start with the flaps open then I close them and then open them again. (sorry about my son screaming in the background haha)
The following 5 users liked this post by C7&7:
.gearhead. (07-20-2019),
CCA Corvette Parts (07-20-2019),
donkeyhoeti (08-14-2019),
Runnn (07-19-2019),
TXGS507 (07-27-2019)
https://youtu.be/-bTPSIKXCls
https://youtu.be/XjU8CWf5cIs
Tks for the awesome post
Regards
Chip
No issues at all with mine.
...and the rear pup cats are behind the last O2 sensors
They are completely unmonitored and are not a part
of the measured emissions as far as the cars computer
is concerned 👍🏻
Regards
Chip
