C8 ERay/GSX/ZR1X ERay/GSX/ZR1X Discussion
Sponsored by: Vibe Motorsports
E-Ray Low End/Initial Pull?
Old Feb 4, 2023 | 11:42 PM
Eaglerulez's Avatar
Eaglerulez
Default E-Ray Low End/Initial Pull?
I'm sure no-one quite knows the answer to this yet, but I figured I'd ask the question.
I own a C8 as my weekend car as well as a Tesla Model 3 Performance as my daily driver.
I generally enjoy both cars, but one of the things that always stands out to me about the C8 after coming from the Tesla is how it takes a few moments for the torque to kick in. Whereas the Tesla just hits you with a wave of torque immediately as you press the throttle.
I'm sure the front electric motor is going to help the C8 with that low-end/initial pull. I'm curious if it will feel as pronounced as a full on EV, or if there will still be some hesitation due to the ICE motor and gear box being involved. I guess the best point of reference would be an Acura NSX but I don't feel like folks generally describe it as an ev-like pull.
Any thoughts?
Old Feb 5, 2023 | 12:04 AM
prosunseeker's Avatar
prosunseeker
I also have an M3P. I think the low end pull will only happen using launch control. Nothing will match a full BEV stabbing a throttle from a roll.
Old Feb 5, 2023 | 08:25 AM
hamta's Avatar
hamta
Any thoughts?
Torque should be immediate (similar to a full EV) as there is no mechanical connection between the LT2 ICE and the Hybrid Motor. Connection is electrical only (via computer inputs/control).
Old Feb 5, 2023 | 09:24 AM
/Bear/'s Avatar
/Bear/
Veteran: Marine Corps
2025 C8 Z06/7/E-Ray of the Year Winner - Unmodified
2021 C8 of the Year Finalist - Unmodified
I agree with @hamta and would add that the E-Ray battery chemistry is designed for very fast charge and discharge. It appears to act somewhat like a capacitor, so I'm optimistic that it will provide the electric motor with lots of juice very quickly, and we'll get the "kick in the pants" acceleration of a fast BEV, like a performance model Tesla.
Old Feb 5, 2023 | 11:25 AM
Hopper12's Avatar
Hopper12
Internet 'bench comparisons' can be interesting. Here's what I see:
  • M3P with awd option: 487 lb/ft; weight 4,250; 3.1 to 60
  • eRay: awd standard; 600ish lb/ft; weight 3890; 2.5 to 60 with all season tires.
Even without using launch control the eRay total torque will come in pretty fast, and any losses 'under the torque curve' while it ramps is at least somewhat offset by lower weight. I think the eRay will be really fun.
Old Feb 5, 2023 | 12:02 PM
dohabandit's Avatar
dohabandit
The Tesla plaid is ~4900 lbs (battery weight), the ERay is ~3800 lbs, nearly 1k lbs lighter!
The plaid has 1k torque (but is much heavier), the C8 has ~400 lbs less torque, but vehicle is also 1k pounds lighter.
This would be an interesting "related rates" problem in Physics/Calculus. It will be interesting to see if the electric motor is able to muster enough torque to fill the gap.
My gut tells me the Plaid will still win in the straight line performance, all the other negatives it comes with though??? no thanks!
Old Feb 5, 2023 | 12:04 PM
dohabandit's Avatar
dohabandit
Maybe the EV motor in the C8 also helps to get the ICE up into its max torque portion of the power band much quicker too?
Old Feb 5, 2023 | 07:33 PM
aquake's Avatar
aquake
There was another member that owns a plaid that explained that the max power for the Plaid for that sub 2 second 0-60 (1k torque etc) needs to have the "battery prepped" which takes 2-10 mins he said. So unless you are drag racing or on a deserted road racing with your buddies its not really street useful. I think he said it would normally be around 2.5ish without this battery prep, launch mode, whatever it was called. So seems pretty even.
Old Feb 5, 2023 | 09:46 PM
Eaglerulez's Avatar
Eaglerulez
Yeah that's what I'm generally hoping for. I mean my C8 is technically faster than my Model 3 when using launch control. But I feel like my Model 3 can go 3.1 whenever I want it to. Whereas when I'm not full on launching the C8 I'm generally getting low 4's or high 3's to 60.
Which isn't bad by any means on the C8's front, but the Tesla's performance is so much for accessible. So I'm hoping the E-Ray has a bit more of that available.
Old Feb 6, 2023 | 09:44 AM
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
My daily driver is a 23' BMW Comp xDrive. While not electric it is turbo'd with awd and the torque is epic/instant, I can also control shift points to more or less aggressive. Feels more like my C7 Z06. I very much missed this in my C8, so look forward to a lot more tq in my ERAY.
Old Feb 6, 2023 | 10:30 AM
RedLS6's Avatar
RedLS6
Well, the ICE in the e-Ray will make a peak of about 7000 ft-lb of torque in first gear at the rear wheels. The ICE's rear wheel torque, per gear, looks like this;
1st gear 7000 ft-lb at rear wheels
2nd gear 4255
3rd gear 2950
4th gear 2127
5th gear 1570
The electric motor makes a continuous 1020 ft-lb at the front wheels, but it will be delivered instantly and will not drop until the motor hits its base speed, which is well below the motor's power peak and likely well below the 150mph cutoff. I think it's going to feel like a very fast ICE with the ICE torque drops on each gear shift, but with an instant off-line torque boost and a constant extra boost from the motor. Once the motor reaches its base speed, the motor torque will begin to drop with speed, but it'll still be adding 150hp to the front wheels up to 150mph. Based on the power graphs given by GM, we don't yet know the exact speed where the motor's torque dropoff happens.
Old Feb 6, 2023 | 10:58 AM
aquake's Avatar
aquake
My tuned twin turbo RS7 is similar, once they moved the turbos into the middle it almost eliminated any lag. I am not through my C8 break in period so I hope it perks up after that cause my RS7 feels a ton faster so far. I am hoping my ERay will eliminate any doubt which is faster...
Old Feb 8, 2023 | 02:07 PM
-ZEEOHSIX-'s Avatar
-ZEEOHSIX-
I'm going to wholeheartedly disagree with that. Now, if we are talking about stock cars, then sure. But, that's not a true statement in general.
More back on point, however, I think it'll feel like a stereotypical AWD car as far as it's acceleration is concerned. It's usable powerband will be much more accessible and I think it should provide a generally pleasing level of acceleration compared to simply stabbing the throttle in the Stingray or Z06.
Old Feb 8, 2023 | 04:28 PM
/Bear/'s Avatar
/Bear/
Your launch control comment made me think of something. Launching my C8 hasn't produced the results I would have liked because my tires have been prone to slipping a little bit too much until they hook up. My expectation is that will be eliminated in the E-Ray because the electric motor will pull hard instantly and allow the rear wheels to catch up without slipping (computer controlled).
On one of the E-Ray videos, the driver did several launches with all-season tires on an unprepped surface at 40 degrees in Michigan, and I didn't notice any tire slip at all. The launches were so effortless, he was easily doing them one-handed with full control.
To E-Ray Low End/Initial Pull?
