C8 Forced Induction/Nitrous C8 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
C8 limits
Old Dec 17, 2025 | 02:58 PM
quick silver 3800's Avatar
quick silver 3800
Default C8 limits
Own a c7 and before I buy a c8 I was curious on the c8 limitations when adding a power adder. The rings on the LT1 force your had when doing the c7. Is there anything like that on the c8 I should expect?
Old Dec 17, 2025 | 11:36 PM
breecher_7's Avatar
breecher_7
The clutch will give up before the engine will. On e85 the stock bottom end will make 750-800 pretty safely.
Old Dec 19, 2025 | 10:45 AM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Seems like some are having issues with the rear main seal leaking when adding significant boost. As breecher 7 states, the clutches on the DCT are probably the weakest link, with most recommending to upgrade them before you get to 600lb-ft. The other issue with modding the C8 is cost. Everything costs significantly more to do than on the C7, with most of the FI kits being in the $20K-$30K range, and cam/heads being in the $10-$15K range, depending on if you do FlexFuel and FBO.
Old Dec 21, 2025 | 02:02 PM
SteveL2's Avatar
SteveL2
1. Clutches
2. $$
3. Lack of measurable performance gains in terms of speed (not hp)
Old Dec 22, 2025 | 10:55 AM
breecher_7's Avatar
breecher_7
For what it's worth, you can get a set of Raybestos frictions and steels for for $550 and they are supposed to have 20% more holding power. The Clutch basket itself is stupid easy to rebuild. If you are looking to stay around 700hp/tq this is likely the route I would go vs dumping all that money on a Dodson assembly. Over that your on the hook for a $7000 clutch....
Old Mar 8, 2026 | 09:20 PM
OkieVette84's Avatar
OkieVette84
1,000% this
Even at LOW boost you will blow the rear main seal. Wound up doing lower compression pistons, venting case, lots of mods, fully building the engine to combat blowing rear main.
The bigger issue is cost vs outcome, due to the crap gearing - power is meaningless until/unless you get up in the 850 900 1000 range. even then, could use different gear ratios.
Old Apr 20, 2026 | 04:06 AM
BlackVal22's Avatar
BlackVal22
Clutches start slipping around 550 to 600 rwhp. So most go to.dodson sportman clutches. People seem to make pretty reliable hp 650 to 750 rwhp without doing a short block. But also same as everyone else, this car needs a tcm tune. Gearing is awful up high.
To C8 limits
