C8 General Discussion The place to discuss the next generation of Corvette.
Code name Zerv
Old 02-18-2018, 12:21 PM
  #681
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Originally Posted by got2bblu
I think these CAD images match the fender pictures.
They match the CAD's drawings for the front fenders, not the [rear]quarter panels as stated on the photo you included.
Old 02-18-2018, 12:26 PM
  #682
got2bblu
got2bblu's Avatar
Yes they are the front fenders. The photo is labeled incorrectly
Old 02-18-2018, 02:18 PM
  #683
Spike5
Spike5's Avatar
ZERV is Back.................
Looks like the headlight to fender question is solved.
vettesweetnos (09-15-2021)
Old 02-18-2018, 02:24 PM
  #684
RapidC84B
RapidC84B's Avatar
Received 13,170 Likes on 5,991 Posts
Love my C7 but this all looks WAY too C7. The headlight is basically The same but longer.
Old 02-18-2018, 02:27 PM
  #685
Spike5
Spike5's Avatar
Based on the new images from ZERV (see bottom row second from left) I’m not sure these pictures are the front fenders?
Old 02-18-2018, 02:40 PM
  #686
TripleBlack99
TripleBlack99's Avatar
once you realize that the rear of the headlight overlaps and sits on top of the front of the fender, then it is clear that the fender in the photo is probably the same as in the CAD. And also, the perspective is slightly different.
Old 02-18-2018, 02:49 PM
  #687
MikeG37
MikeG37's Avatar
There's a few spots that resemble some of the lines but there's WAY too much distance between the wheel opening and the top to be a front fender for this car. They almost look like they'd fit a SUV.
Old 02-18-2018, 02:54 PM
  #688
TripleBlack99
it matches the CAD. If the CAD is genuine (likely) then this is the fender. Maybe you think this because you imagine the headlight is above this panel, but it overlaps with it. Also the perspective might be throwing you off. This panel isnt much different from a c7 panel. http://www.nocarnofun.com/wp-content...-side-view.jpg Since the view is kind of from above, i think the fender height looks taller, but it were a direct side view i think it would not look so tall.
Old 02-18-2018, 03:00 PM
  #689
Spike5
Spike5's Avatar
Ahh hah! Didn’t see the indentation in the actual fender. Makes sense now.
Old 02-18-2018, 03:03 PM
  #690
Speednet
Speednet's Avatar
I think we're definitely getting all-LED headlamps. I can't see a non-LED light fitting into that module.
Old 02-18-2018, 03:15 PM
  #691
Spike5
Spike5's Avatar
Hopefully laser.
Old 02-18-2018, 03:59 PM
  #692
Paulchristian
Paulchristian's Avatar
It looks like the headlight shape protruding into the front fender is similar to how the taillights wrap around the side of the bumper Symmetry...I like it. Also, we see some hood in the latest pics provided.
Old 02-18-2018, 04:02 PM
  #693
RapidC84B
RapidC84B's Avatar
Originally Posted by Paulchristian
It looks like the headlight shape protruding into the front fender is similar to how the taillights protrude into the rear fender. Symmetry...I like it. Also, we see some hood in these latest pics.
C7 fender/headlight is the same... this is a stretched out C7 light with a little sharper point up front.
Old 02-18-2018, 04:10 PM
  #694
Paulchristian
Not sure what you mean. The point I am trying to make is that the front headlights intersect the front fender with a shape that is consistent with the way the tail lights intersect the side of the rear bumper.
RapidC84B (02-18-2018)
Old 02-18-2018, 04:20 PM
  #695
Spike5
Spike5's Avatar
I can see the front trunk/storage area in an image. Where are you seeing any of the hood?
Old 02-18-2018, 04:36 PM
  #696
Paulchristian
Sorry...I meant front trunk...forgive me, the engine has been up-front for 67 years...
Old 02-18-2018, 05:08 PM
  #697
f-16pilotTX
f-16pilotTX's Avatar
Thank you ZERV
That "frunk" sure reminds me of a Lamborghini one. As long as it has enough room for some small groceries and beer, I will be okay! Sorry for all the corvette golfers, lol.
The headlight assembly does look similar to the C7, but what really interests me in not the shape of the housing but the structure, design, and layout of the LED bulbs... That is where the beauty comes in!
This is going to be a long couple months, especially after the excitement of C7Pimps post. Along with John Elegant, I too have my deposit in with Mike Furman.
Cheers
To Code name Zerv
Old 02-18-2018, 05:25 PM
  #698
LT1 Z51
Corvette Enthusiast
Support Corvetteforum!
LT1 Z51's Avatar
Hopefully laser.
Not legal yet.
Old 02-20-2018, 07:37 PM
  #699
SBC_and_a_stick
SBC_and_a_stick's Avatar
Also shows a radiator/heat exchanger under the headlamp and appears to line up with the front fascia openings we saw in the paint booth photos.
Indeed. The C8 will use front side mounted HEs.
Old 02-20-2018, 09:00 PM
  #700
Quinten33
Quinten33's Avatar
That’s pretty cool...
So I assume lines will run to and from the front heat exchangers via the structural tunnel that runs through the floor pan. Maybe GM will use 14 heat exchangers on it and set a new record...
sunsalem (02-20-2018)
Quick Reply: Code name Zerv
