Probably a silly concern about ME design, but...
Lots of HP under the hood makes me happy, but the idea of lots of HP right behind me makes me uncomfortable. I'm not familiar with ME cars (I rode in a fiero in the '80s), so maybe it's a non-issue, but I'm wondering if the engine being so close to you gives others pause, as well. I rode street bikes for many years with the engine between my legs (not to mention the gas tank in my crotch), and it never bothered me. The ME thing might be bothering me because of the insane physical forces in these high performance engines. 850hp right behind my head? Yikes. Is it just me?
Miles of Smiles
2016 C5 of the Year Finalist
Plenty of MEs out there for you to research safety stats.
Not to worry. The biggest risk in any high HP sports car (ME or not) is likely the ability, and/or judgement of the operator.
The following 2 users liked this post by FrankLP:
gurneyeagle (01-05-2018),
SpeedyD (01-02-2018)
fugly1 (01-02-2018)
For the OP, on the other side you've probably driven cars in the past with a spinning clutch or torque converter inches away from your right foot and never thought twice about it. The ME should be relatively safe.
It is overall better. For 1 you don't have hot exhaust travelling under the whole length of the car. Either design you have a firewall separating the cabin from the engine. That engine weight is also more distributed over the rear axle thus making it safer to put the power down. Not that this seems to be much of an issue anymore but in the event of a clutch explosion it isn't sending parts into your legs.
50/50 weight distribution is a bogus figure, polar moment of inertia is what matters which is much better with mid engine making them turn better.
With ME you can run smaller front tires that help to eliminate the car from from following the grooves on the highway.
Engines these days are designed to drop to the ground in a big collision rather than being pushed into the cabin.
Here is a picture of a wrecked Ferrari Enzo at very high speed.
In the foreground is the engine...in the background is the rest of the car forward of the engine:
Cars with the engine located in front of the driver normally have the gas tank(s) located behind the driver. Maybe the mid engine Corvette will have the gas tank located in the center tunnel(as did the Pontiac Fiero) where it will be less likely to be damaged in a rear ender, thus less chance of a fire.
A modified Mazda detonation shouldn't give anyone buying a Vette anything to worry about.
Ok, so maybe I am the only one....
But you guys have not quelled my neuroticism. I will probably just have to continue to suffer with an FME design, big V8, manual trans, and rwd. Oh, well.
If you find this situation uncomfortable, I suggest you use Google to research this issue with other MEs (Ferrari, Lambo, etc.).
If that doesn't work, there is always Valium.
I drove a Lamborghini Aventador in Vegas for a few laps. Very unusual feeling to have the engine "push" you through the corners. If I get a ME Corvette, it will take some getting used to for sure.
I did too at Exoticsracing.com and it was a huge disappointment.
That's the AWD talking to ya.
You can't turn in quickly (like you can with a RWD) without a healthy shot of understeer.
Next time you're there compare it to a 458 or a 488...big BIG difference.
I hated the frickin' Lambo and vowed never to buy an AWD Sportscar.
CliffB-99 (01-07-2018)
Received 8,928 Likes
Bill
My opinion is AWD combines the worst characteristics of FWD and RWD in one vehicle. My Tahoe is an AWD setup. Not Full Time 4WD, AWD. It has more under steer than a RWD Tahoe and has more more power on over steer than FWD vehicles. It can downshift when going through a turn under power and when the shift happens it will change lanes due to the severe under steer exhibited.
Bill
Bill
Almost impossible to put one in understeer on the highway...even when pushed to the edge.
The Lambo jumped into understeer so easily, so quickly it stunned me.
