The 4.2L, 2020 Corvette ME’s Motor
#41
The Consigliere
Received 5,457 Likes
If it does, it's because they had no choice. Not like the engineers WANT to do it...they do what's necessary to build the car to a level of performance. I think a lot of people lose sight of the fact engineers don't enjoy putting CAGS functions in and doing cylinder deactivation...it's a necessary compromise to build something beasty with all the regulation bs.
Hopefully they find a way to keep it off.
#42
Reading the Cadillac’s official press release, it does say 3,000 in quantity. It says nothing about Corvettes. So if hypothetically, there were 19,000, 32 V, DOHC, TT, V8’s going into the 2020 ME Corvette and an additional 3,000 of the 4.2L’s going into the Cadillac, Cadillac's press would be right (that is the only media source I know is correct), and there would still be plenty of motors for the Corvette.
elegant (03-22-2018)
#44
I'm of the opinion, Engine 1 got cancelled. That was supposed to be the NA Flat Plane Crank based on the 6.2L LT1 made DOHC. Doens't mean it got deleted from CAD.
Engine 2, is from this family. The heads could be differnet to not do a hot V (it's possible to support both). Why GM would do that? I'm not sure, it makes sense to keep the design as is.
It makes absolutely no sense to have two different DOHC heads for such a low production engine.
I'm of the opinion that the NA 6.2L LT1 design engine will be the base engine for the ME, and there will be a 6.2L DOHC TT(and not a HOT-V design) for the HP model of the ME. Until I see a CAD drawing of something other than the above, I'll stick with that opinion.
I'm also of the opinion the C8 will be a FE car and that there is a possibility that the FE C8 will have the 500HP DOHC TT HOT-V as the base engine and the 550HP HOT-V will be for a GS model of the FE C8.
I'm also of the opinion that the FE C8 will be the high volume base car and the ME will be a high MSRP/low volume, high performance car, with it's own nameplate(Zora, etc).
My opinion is that the 4.2L TT Cadillac engine has been in R&D longer than the ME car has, thus the Corvette engineers would know it was being developed and that CAD drawings we have seen would have shown the HOT-V TT V8 if that engine was going to be the base engine in the ME, as is your opinion.
Just like your opinions, my opinions are just that with no factual basis, other than what we have been privy too, such as the CAD drawings, with some common sense thrown in based on 65 years of Corvette history
I don't believe that GM has placed all their eggs in one basket(ie: 100% mid engine cars with no FE version).
AORoads (03-22-2018)
#46
Corvette Enthusiast
3) the CAD drawing of the engine/transaxle cradle clearly show that it was designed for an engine with the turbo's mounted low and to the outside of the heads.
#47
Question:
Would we prefer having more fun conjecturing for the next 9 months, or would we prefer knowing today, exactly what will be revealed on January 12th?
Reveal day is 296 days from now (when I first calculated it, it was more than 600 days. Wonder if anyone “tap outs” in this section — can’t cope with our chosen form of anticipation.
IF GM had $1 for every one of our wrong conjectures in our C8 section (including mine too of course), they could price the 2020 ME at $49,999 and still make a profit on its run.
The following 4 users liked this post by elegant:
#48
Corvette Enthusiast
TBH,
Since the CAD leaks my information has almost entirely dried up. I'm running on rumors, my previous knowledge and my industry experience.
Things could go sideways real fast here.
I did not anticipate a Hot-V engine.
#49
Start/Stop has to be "auto-enabled" to qualify for the MPG increase on the sticker.
There are ways to disable it, but most of them involve finding what the inhibits are and spoofing the CAN message (or changing another module to think that it doesn't have the feature and always request it be turned on).
And Engine tune will also be able to delete it, like DoD/AFM.
On our BMW you only turn off once and it stays off. The 1st time it enabled I thought what a pain in the *** to drive with this thing enabled full time or to have to turn it off every time you start the car. Most annoying option ever!
#51
Corvette Enthusiast
#52
That said, there are a lot of folks on here that seem to have a pretty good working knowledge of how things work around GM and Bowling Green.
Me, I have no real freaking idea. My thoughts are simply based upon my basic knowledge of automotive mechanics and systems, general understanding of the automotive market, and the idea that within GM's design and marketing, the best predictor of future behavior is past behavior.
Other than someone slipping a little truth serum into Tadge's whiskey, this is about all we're gonna get.
JerriVette (03-22-2018)
#53
The CADs could be from reboot of ME program, disinformation or other. I've disregarded the technical aspects only taking away that an ME has development history and is progressing in development. I did not expect expect Hot-V configuration for ME and it may only be for Cadillac and FE C8 depending on entirety of packaging. We don't know what we don't know.
#54
A hot-V V8 seems great for a ME Vette, since you can more easily route the exhaust than you could in a FE vehicle. However, the CAD showing a traditional V8 seems to imply that the engine won't be a hot-V design.
Also, the undersquare design does not seem appropriate for a sports car. Nor does an engine making 600+ lb-ft of torque but "only" 550 HP. That means the engine is peaking way below 5000 RPM. Great for effortless performance with decent fuel economy (due to low RPM operation), but not very exciting.
Larger turbos could push the torque peak higher in the RPM range, improving power and feel, but the undersquare design would likely remain. There really isn't a way to significantly affect that without making large changes to the design. I guess with appropriate turbo mapping the undersquare aspect isn't much of a detriment.
Still, the more I think about it, the less I think this engine will be used in the Vette. Maybe a sportier version of it will make in at some point.
I really doubt this would be used in a front-engine vette, which I think will stay with updated versions of the LT1. I think the low hood of the vette might suffer too much if an engine like this were used.
Regarding start-stop tech, I would be OK if the car had an ECO mode or something where that was enabled by default. You could also have the "touring" mode where it was not. Of course it would also be disabled in the even sportier modes. Maybe the car would start in either ECO or "Touring" (whichever it was left in when shut down), which would provide an option for the tech to be enabled by default (for EPA purposes) but also an option for it to be disabled by default (for enthusiast purposes). Anyway, it seems like there might be ways to elegantly handle that situation using the drive modes. Perhaps that would also give them a way to more easily disable the skip-shift as well (assuming a manual transmission is available).
-T
-T
#55
Received 9,530 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
I don't think the Cadillac engine that has been revealed will go into a Corvette. Will a close variant go into the ME? Possibly...likely. Will the ME be a Corvette? Much speculation being made in all directions.
#56
The Consigliere
For the love of Zora, the ME needs to be a Corvette.
#57
2015 C7 of the Year
I think it needs Zora's name on it for sure!
#58
The Consigliere
E.T.D. Corvettes (03-22-2018)
#59
Things to like:
hot V
sturdy enough to handle that torque figure
Things not to like:
There is no variable valve lift like in the M5's engine, aka Valvetronic III
Pistons are cast
Much smaller bore than M5's engine which means it's not only lower displacement but has little room to grow as it's already a stroker
It runs 20 psi, little room to mod here even if cast pistons don't crack easy
Overall, this is catch up to a 2010 engine made by BMW, the S63B44O0. In 2018 BMW's V8 is much farther ahead, and BMW already sells the engine, so we're really looking at 10 year old tech.
I'm a bit underwhelmed but say you get an ME 'Vette with this engine at $55k...well that would be a good deal.
hot V
Things not to like:
Pistons are cast
#60
I also hope that it would be called a ZORA!
However, if it were to be a ZORA, would it a ZORA all on its own (e.g. a Corvette not being a ZORA, nor a ZORA being a Corvette)? Or would it be a “Corvette ZORA”?
