Manual a thing of the past?
#61
Luckily, your opinion doesn't matter to me in the least. I do understand the skill it takes since I have owned clutch pedal cars, including a 2008 Z06. I did enjoy the skill that I had to use to shift that car to get the most out of it. But as I age, and the body rebels, I found I can get just as much pleasure "toggling flappy paddles" and guess what, I'm still getting just as much thrill as I did with the three pedal cars. Maybe even more as I enjoy the times I don't HAVE to utilize that skill. Times like driving the 405 freeway in S. CA. for example. Lastly, I am not practicing to be a superior race car driver, rather I just enjoy driving high performance cars at a level I am comfortable with. I have found with age that there are a number of "skills" that I don't need, or want, anymore. Manual shifting has dropped off my radar as a fun way to drive MY cars.
Sadly mistaken? That's just your opinion. You are sadly mistaken if you think that shifting an H-paddle shifter makes you a better driver, or makes it more rewarding, than folks who don't care about them anymore.
Shaka (07-12-2018)
#63
Supporting Vendor
Received 2,316 Likes
There is always the factor that one can "drive" a manual, and then one can truly "utilize" a manual. If you can drive point a to point b, maybe do a little quick shift or power shift under acceleration, you can drive a manual. If you can match rev downshift, heel-toe at the threshold, left foot brake, clutch kick...then you can truly "utilize" a manual. That said, newer automatics are quite tempting, especially if you develop your left foot braking ability on track. You can accelerate deeper into the corner because you remove the transition time, plus you can run the tire closer to the edge of adhesion by being two hand precise.
I think it's clear that removing the manual gear lever and third pedal is FASTER, but if you can truly drive and fully utilize a manual gearbox, you put yourself in a very small category.
elegant (07-13-2018)
#64
Im hearing the C8 will only be offered in automatic......How true is this? I'm guessing it will be more accepted if its only paddle shifters...
Not like the present auto set up where you see the shift column of P R N D.......To me there is def something wrong when I see a Z06 or a ZR1 and you see P R N D.......Sacrilege......That's just me....
i rarely even use the auto paddles
#65
Received 1,267 Likes
2021 C1 of the Year Winner - Unmodified
2020 C1 of the Year Finalist - Unmodified
2016 C1 of the Year Finalist
I have owned, driven and raced Corvettes for over 40 years, and I have always specified a manual transmission. I could not even imagine enjoying a Corvette with an automatic transmission.
I was wrong.
My C7 is an absolute delight with the automatic. And yes, if you really want to get the most out of it, there is still a learning curve. There will always be those who will cling to their manuals - I was one of them for decades - but it's time to acknowledge progress and product development. The "state of the art" has moved on. Time to move with it. Just my opinion, of course - but it's an informed opinion.
I was wrong.
#67
pdiddy972 (09-03-2018)
#68
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
I have to add another issue I have with a manual, and I am narrowing this down to Corvette manuals for a reason. The manual transmission in my Z06 was the absolute worst manual I ever owned. I have been driving over 50 years and never had ANY issues with the other manual cars I owned other than needing a new clutch itself on occasion. In the C6, if you didn't do constant flushes your clutch fluid would turn black (contaminants entering the system) in a short time. Never had that problem in any other car. My Z06 clutch would sometimes hang on the floor especially during hot pedal to the metal acceleration runs, think drag strip. Again, never had this problem in ANY other car.
Since I haven't owned or even driven a C7 I can't comment on them. But the C6 manual tranny left a huge bad taste in my mouth.
#69
Along with the brake fluid. They should both actually be every 2 years but this is working for me.
ByByBMW (07-12-2018)
#71
"Driving skill" and "operating a clutch pedal" are not necessarily correlated. A driver's ability to manage grip, contact patch, weight balance, limit braking, throttle management, etc has nothing to do with their ability to use a clutch. Some of the MOST skilled drivers you will find at a track day will be in a DCT. Your conclusion that only skilled drivers can operate a manual is not accurate. Nor does the ability to operate a manual mean you are a particularly skilled driver.
The following 3 users liked this post by gthal:
#72
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Nonsense........
They chose to have the car shift for them because they couldn't handle shifting duties and wanted to participate. Then, they realized the trans couldn't even shift as fast as a skilled driver with a manual transmission. Automatic trans owners are just early adopters of self-driving cars.
NONSENSE........ While a fully automatic C6 upshifts extremely well for what it is.... In AUTO or PADDLE mode, and fantastically better after I've tuned it up....
Don't think that you or any real professional "DRIVER / "SHIFTER" can out SHIFT a C7 with a proper tune.... IT WILL NEVER HAPPEN.
And that is why GM isn't going to make a stick any more..... Now-a-days.... You CAN'T out do the computer and for those of you who think you're AMAZING
stick shifters.... All you're doing is grinding and breaking 100 year old technology synchronized manual transmissions into bits so your car can come off the
road sooner to have major repairs made......Again, REGARDLESS of how good of a "shifter" you think you are..... the antiquated synchros are like aggressive
race brake pads destroying your rotors with every touch of the pedal..... While the new Automatics will last way longer, shift faster, and win more races.....
That's why there will be not more sticks.... it's 100+ year old silly stuff.
NOW, I wouldn't want an AUTOMATIC C2 or C3 Corvette..... but again, the automatics are sooo far advanced now you're insane no to have one.
You can't even buy a stick shift truck any more either..... cause they fall apart prematurely..... OLD SCHOOL STUFF.....
Chuck CoW
#73
With the 458 under braking you can pull the downshift paddle and it will continue to down shift until you reach the desired gear.
The downshift are lighting quick so anything you chose to do with a manual you can do faster with a DCT.
Have you every driven a DCT in a high performance sports car like Ferrari Lamborghini or Maclaren?
Yes, I have driven and owned a DCT, I prefer the manual. I like to pull away from a stop sign, run the car up to Redline, then shift into top gear without using any other gears.
I know the DCT gear shifts are faster, sometimes one wants to take a few seconds between gear engagements. Nor do I care about ultimate track speed, it has a lot more to do with being involved with the car, and the driver being made to excise control over the car. Nor do I particularly like the car blipping the engine on down shifts, take the car out of gear, brake to a stop, engage 1st gear about 3 feet before stopping and be ready to go when the light changes. No blipping avoids constabulary observations.
#75
Received 4,377 Likes
You are over rating the skill required for a MT... it really isn't hard to master and once someone does, it's second nature and doesn't require much more thinking than a DCT. I say this having spent hundreds of hours on a track in cars with both transmissions.
I don't race for a living. When I drive on a track, I want to know that the reason I was able to achieve the time I did, was in large part due to my driving, not the cars automated systems' driving. Not everybody is like that. Some just want the best time. I like the tactile interaction that a manual gives. I am old enough to remember the difference in feel between a car with mechanical secondaries and vacuum secondaries. Now you get the dead feel of the pedal with drive by wire.
Everyone is different in what is important to them in the car driving experience.
SBC_and_a_stick (07-16-2018)
#76
I have bad news for DCT lovers. DCT will bite the dust only a day after the 3 pedal H pattern stick. Automakers now believe full electrification is the future with hybrid only a stopgap measure. It is already hard enough to have gear choice with DCT in a hybrid, and I suspect many hybrids will ditch it as well.
Believe it or not, DCT is in the same can as the stick - to be read as, it's going to be canned.
The other thing that's going to bite the dust with the "OLD SCHOOL" stick, is going to be tuning. Tuning is going to be "100+ year old silly stuff" with fully electric cars.
Chuck CoW
Chuck CoW
#77
#78
Got news for you, tuning will not 'go away' with electrics, there's always a better battery, more voltage, higher amperage, a different wind motor, changing the curve on the electronic speed control (ESC), tuning the drive-train for better traction, gear selection for the type of competition, buying lighter components, more efficient accessories to be able to use more of the available power for speed and duration, this is stuff I am already doing with my electric 'toys'.
Wadoka (08-26-2018)
#79
Porsche tried to kill off the manual GT3 but there was a massive uproar and the manual is here to stay. I'd expect the exact same thing to happen if GM tries to kill off a manual vette.
people can say/prove an automatic is faster as much as they want but the fact is manual people just don't care and I for one will never drive an automatic sports car regardless of how much faster it is.
#80
All that said, I am not suggesting the Corvette will go all electric anytime soon.
