chazcron's 3D model work in progress
#2821
The bottom blue C8 facing forwards (left) looks clean. Smooth flowing. The *** end looks like a mess. Here's to the 18th.....
#2822
TH please consider this. If there is that trim piece you note in green then this open door pic with Tadge and Mary is correct. I submit that pic is just Camo thus extends out way to far with the door open. The much smaller red segment I drew is likely more probable, Although not to say there is no trim piece but rather it is much smaller.
Why then do I think this? Because of that Tadge/Mary pic. There is no need for the door scoop area to be that large to be able to incorporate a pad underneath for your hand to press while pulling on the door. It’s all part of the charade.
KISS
KISS
Now if you are being carjacked, that's a different story.
The following 3 users liked this post by Michael A:
#2823
It's a new GM safety feature to attract more female buyers after the #metoo movement.
Michael A (07-10-2019)
#2824
If there is any scoop on the door at all... that is...
The truth is out there. 18 JUL
/Scoop Truthers secret member
chazcron (07-10-2019)
#2826
Have wondered that same thing about the side area with hidden door handle. With all of the renders I would guess that none are right so far....can't believe they would put this in production that way
#2827
I just stitched a YouTube pan shot together, this might be better:
The following 4 users liked this post by chazcron:
#2828
OK, it was slow enough at work to go ahead and render these out. I cheated by rendering each alone, so no reflection, and I cheated the perspective, but it's not noticeable at first glance.
The following 30 users liked this post by chazcron:
'Shifter (07-10-2019),
AEmedic (07-11-2019),
Corvette_Nut (07-10-2019),
dmaxx3500 (07-11-2019),
elegant (07-10-2019),
and 25 others liked this post.
#2830
Maybe you can flare the fenders, widen it out, add some ground effects and show what the Z06 will look like lol.
The following 4 users liked this post by benplace:
#2831
Location: Hailing From The Mean Streets Of Irvine, California
Received 4,153 Likes
ChazCron, Thank You Sir! This render is Remarkable! YOU have consistently Delivered. YOU have made the entire Unveiling Process of the Next Generation Mid Engine C8 Corvette Exhilarating! And for that, I Thank You Kind Sir.....
Save The Wave,
Corvette_Nut
The following 9 users liked this post by Corvette_Nut:
benplace (07-10-2019),
chazcron (07-10-2019),
GundamX7X (07-10-2019),
lusluckylad (07-11-2019),
and 4 others liked this post.
The following 4 users liked this post by 'Shifter:
#2835
We all need to lobby GM to give ChazCron and a guest passes to the reveal.
Rapid Fred (07-11-2019)
#2836
I totally agree with this. He has made the entire pre-reveal process much more exciting as bits and pieces of the design have trickled in. His dedication to the entire process has been unflappable. Frankly, I'm going to miss these renders.
kratedisease (07-11-2019)
#2839
#2840
Chaz, are you getting reimbursed for all the people trying to make money off of your renderings on youtube? Just curious. You've obviously put in a lot of hours, seems crazy someone could just steal your photo and use it as clickbait to drive ad revenue.
