GM Authority: C8 Delayed 6 Months Over Electrical Issue
#161
CorvetteBrent (12-15-2018)
#162
I hope we're 2 months in to the 6 month delay...no mules have been spotted in 2 months
#163
Jerri, you don't think they could clear out C7 inventory in nine months? It seems like that would be plenty of time.
#165
I have two guesses, both involving limited hang outs in which the insider's info tells only part of the truth. The first is that they misjudged the cooling requirements of the later twin turbo engines. Upping the cooling capacity would require more powerful pumps, and probably a need to run the cooling system after engine shut down. GM would want to standardize electrical systems across C8 models as much as possible to reduce costs so the entire C8 program may be delayed to engineer and validate a more robust electrical system that can power a more robust cooling system.
My second guess is based on two shards of info. The first is that sources from within GM (on the base engine) have told us that the C8 would have a big surprise at its unveiling. This is from sources that also say it wil have an OHV engine derived from the LT1. So what's the great surprise? Second shard of info: the 7th gen Camaro is rumored to feature a flywheel-based kinetic energy storage system with the total system weighing less than 200 lbs.
Since GM introduces new performance engines in the Corvette and soon after in the Camaro, my bet is that the C8 will debut a bleeding edge kinetic energy storage system. Yet another piece of this puzzle that fits is unlimitedPower's claim that the LT1-derived engine will have 520hp yet only 485 lb-ft of torque. Perhaps the engine was tuned for less torque because the kinetic energy system will provide low end torque? If true, then this would indeed be a big surprise and it would be technology that GM could apply across their ICE vehicle lineup to increase both fuel economy and performance.
#166
#167
#168
I think car manufacturers have auto start stop the wrong way. Instead of pressing a button to turn the system off every time you turn on your car, you should press a button to turn the system ON when you turn on your car. If you know you're going to be doing a lot of city driving, or just plain stop and go, then you can press the button when the need arises. I know a lot of the auto start stop delete kits have it working this way so if you want to turn the system on, you press the button that used to turn the system off.
#169
Depends on how much torque it adds and the C8's total weight. Agreed that if it results in a 3800 lb vehicle then it's not a good trade off. But to be really strict about weight trade offs would result in a C8 that is more like a Miata than a Corvette.
#170
This thread is ridiculous! How does anyone call something delayed when it was never planned anyway? Can anyone quote a definitive announcement of when this vehicle was going to be released to the public? The answer is, no! Relax people! to quote a friend with insight: It will come out when they are 100% satisfied it will be correct from the beginning of production. Any hiccup will be scrutinized.
#171
Received 8,928 Likes
curious, what is the date of that photo? Seems like they should’ve been working on the problem then, not waiting until now! Of course the 6 month “delay” could be from that point causing a NYC debut?. Seems a bit odd to have an electrical issue of this magnitude, all calculations should have been done from the beginning.
Manufacturer's have been doing a lot of things to increase electrical system capacity as well as reducing weight of the electrical system. One of the things that has been talked about for a couple of decades is going to a 48 Volt electrical system which would let them cut down on the electrical system weight.
Or maybe they routed a harness in the only place it could go and then found out that it really couldn't go in that place because of some issue that didn't turn up until they started driving the prototypes and getting some miles on them.
Bill
#172
Michael A (12-15-2018)
#173
If you call this thread ridiculous, then what, 99% of the threads in this C8 section are?
Maybe this is all false, and we get it at NAIAS in January.
#174
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
I.....Second shard of info: the 7th gen Camaro is rumored to feature a flywheel-based kinetic energy storage system with the total system weighing less than 200 lbs.
Since GM introduces new performance engines in the Corvette and soon after in the Camaro, my bet is that the C8 will debut a bleeding edge kinetic energy storage system. .
Funny, been a flywheel energy storage fan since I stared investigating ~1982/3 (the government had an extensive document on the subject during the Carter Years, when we knew we had to do something! I'm also mechanically inclined. I was in CT looking at solar homes, not solar cells but big windows on the South side and energy stored I rocks in the basement! Moved South in 1985, it was easier!
For the first KERS effort in F1, ~2009, some cars were used flywheel storage and Porsche had/has their flywheel storage 911 racer. But now all F1's are using batteries. About half the 60 to 75 lb reported weight of the current 160 hp F1 systems is a battery. However in making it dependable I assume a similar system put in a Corvette would also weight closer to 200 lbs.
F1 has improved their efficiency over 50% with a smaller cid engine (1.6 Liter producing over 800 hp itself) with a 160 hp KERS that recovers all it's power when braking! They are beating old track records and refueling is not allowed so with less than ~half the fuel!
The C8 would be the first production car with the system BUT doesn't sound like GM to take that risk- at least not with the first C8 offering. Hope they did- worth the 6 month delay! Would make Tadge and Mary Barra look smart and "green leaning!"
#175
#176
In 2009 they were allowed 100 Kg of fuel
In 2018 they were allowed 105 Kg
in 2019 they will be allowed 110 Kg.
So, its more like getting a bit more power 2018 F1 = 1000 HP from less fuel 105 Kg compared to V10 era 950 HP from 150 Kg.
Reported thermal efficiencies of the current F1 engines are around 50%.
And with a lot more low end grunt at the same time.
#177
I love all the armchair engineering on this forum....
EE is so easy, anybody can do it, obviously
if it really had a delay due to electrical issue.. I would imagine it would be related to a hybrid setup IMO if it was that serious of a delay.
#178
C8 electrically driven alternator
I was indeed kidding about that. Almost.
The heart of any hybrid, OR any vehicle that adopts a 24 or 48V electrical system is gonna be the inverter. That which changes AC to DC, DC to AC, and AC/DC to 3-phase CW --- Country Western.
You've got all these light bulbs and other legacy stuff that still requires 12V, unless you've re-engineered every single thing, down to the radio, headlights, horn,
You'll probably want the inverter to make 5V (or 3.3) for all the electronics --- ECM/BCM/TCM/.... modules, LED dash, etc. Why make 5V inside each individual module for all the chips & sensors?
You've got to power any electric motors you want to run -- starter, water pump, electric steering, electric air conditioning, power windows & seats... have 100% of them been re-designed for 24 or 48? Traction motors are likely to want 3 phase AC if they're like every other hybrid out there. Inverter converts DC from the high voltage battery into 3-phase...
You've got to interface with whatever batteries are installed. 12V so you can jump start it? 24 or 48? High Voltage for hybrid? Do you want the HV battery to be able to "charge" the 12V battery? How fast?
So you gonna have an alternator putting out raw AC to the Inverter, to avoid the rectification losses (heat) made by a 150-200AMP generator? Ya gonna water cool that big azz alternator. Oh boy, more plumbing.
If you don't correctly determine 100% of your loads under 100% of conditions --- Arizona heat, Minneapolis cold, 150mph, crawling 3 mph in traffic... you may have undersized one portion of the inverter. Do not pass go, go back and re-design the Inverter.
And that's how you end up with a 6 month delay because of "electrical issues."
Foosh (12-17-2018)
#179
Bingo! No way GM discussed a issue about a car that they do not even acknowledge is in the pipe line.
GM standard answer is we DO NOT DISCUSS POSSIBLE FUTURE PRODUCTS.
Everyone on the forum always states they cannot reveal their source for information .
So does anyone really believe that a GM employee would acknowledge that their are developmental issue with the future unannounced flagship?
I say no way if they risk their job just acknowledging the car is in the pipe line they definitely get fired for discussion of issue with this unacknowledged future car.
