Please, Chevrolet....NO Start/Stop Technology on C8
#141
Yes, I had a CAGs eliminator on my C6 Z06, but have found absolutely no need for it on the C7. I never shift before 20 mph or about 2500 rpm even when cold. For those who want to "granny shift," do it before 15 mph, and you won't see it either.
#142
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,437 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
My Jaguar F Type R had a defeat button for the start/stop. The sequence for me was push start button, push start/stop defeat button, push exhaust valve open button. If the C8 does incorporate start/stop, please give us a defeat button or a mode that bypasses it.
purple heart (02-09-2019)
#143
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
Lets at least have the last generation internal combustion engines with improved energy efficiency, i. e. smaller cid, double overhead cam, twin turbo prove 500 + hp and improve the current 15% energy in gasoline that gets to the rear wheels!
Of that ~15%, about a third also goes into heat braking. We can recover some and get ~150 more hp with a 100lb F1 KERS type system.
I’ll accept a quality Stop/Start system like we have in our 2018 BMW X5 SUV way before I have to plug my EV in every night!
Side Bar:
I also like stake and AOC’s bill will lead to no cows as they fart a great deal of methane! Hmm, guess that also means no refried beans!
Here are some facts re cows:
"Their wind (farts) and manure emit more than one third of emissions of another, methane, which warms the world 20 times faster than carbon dioxide. Livestock also produces more than 100 other polluting gases, including more than two-thirds of the world's emissions of ammonia, one of the main causes of acid rain. So get ready to eat Tofu!
Continuing:
I recall the fellow from NASA who was demoted for saying “Why do we think the current temperature is good for all people in all places! Bet the folks in Minnesota would be happy to be 10 degrees warmer. Agree IF this warming is not a natural cycle, folks in Florida etc will have to move! There are other scientists who note that increased warming increases clouds that block the sun's radiation. This analysis from 2017 from Lawrence Livermore National Labs states: . “These results suggest that low cloud anomalies induced by the spatial sea surface temperature pattern could have contributed to reduced warming between 1998 and 2013.
I certainly don’t know what will happen with “Global Warming” but from my experience with the research on the impact on welders of fumes generated - you have to watch who is funding the work!
#144
Start/Stop technology is here to stay, at least until the electric revolution renders it unnecessary. The good news though is that many manufacturers are now allowing you to disable it permanently if you don't want to use it. Meaning, you can save your settings so that the system is turned off when you start the car next time. BMW has been doing this for a while. Porsche and Volvo are now doing it as well. Can't vouch for others. Some are even going back and updating software on their prior models to allow you to disable the system at your discretion.
#145
do you feel the $300 you spent on one or more AGM batteries have saved you money?
#147
Stop/Start is NOT there for you to save money! It's to reduce the energy waste when cars are at idle. Helps manufacturers meet required mpg goals.
Also we had our BMW X5 SUV operate just fine with it's AMG battery for 4 years. Traded it for a new X5 that just turned 1 year old. We never shut Stop/Start off- no need. It's seamless, don't know the engine is off when the radio is on, can't get to the gas from brake before engine starts, don't hear the starter motor!
Many companies are now shutting the engine off right after a cylinder fires and that cylinder pressure turns the motor to assist the starter in restart! Yep it can be done well. The BMW goes one step further, with more stress on the battery. It only charges that AMG battery when coasting or braking. Alternator is NOT functioning other than those times. Have a dash gauge to show when it operates and when you're recovering braking energy. Worlds changing!
Most cars have only ~15% of the energy in gasoline getting to the rear wheels. Time at idle is part of that waste. About 30% goes out the exhaust and another ~30% heats up the water in the rad! Of that ~15% that does get to the rear wheels about a third turns into heat when braking! Some of that wasted energy can be captured.
#148
Another point I'd like to say and not to steal your thread is I wish Corvette would have the automatic folding mirrors when you lock the car. Again, I had it on the Jaguar and initially it took a little getting used to but it's an option I wish was on Corvette's menu.
Sal
JerryU (02-10-2019)
#150
I also had a '14 Jaguar F-Type w/ start/stop that I left on all the time. A driver can modulate whether it engages or not with brake pedal pressure, which is the same with my current Jeep, and it was also the same on my wife's '15 MB C300. It took very firm pedal pressure on all 3 to cause engine shutdown when stopped. All restarted w/ zero hesitation.
My '14 Jag had a large AGM for regular use, and a smaller battery for start/stop. In later MY cars the small battery was dropped because it was found to be unnecessary.
Some folks are rigid, make up their minds they hate something, and will never change that perception. Others are open-minded, receptive to trying new things, and ultimately embrace them even if they were initially skeptical. It has been forever thus.
msm859 (02-11-2019)
#151
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
One other group exists, the open minded ones who were receptive to the change, tried it and it didn't work for them. I am in this third group as to start/stop.
Foosh (02-10-2019)
#152
I suppose that's true, but that group is a real head-scratcher for me in the case of start/stop. I suppose there have been some poor implementations of the system. I just haven't experienced one.
Perhaps others experienced it on a relatively short test drive, and didn't gain enough experience with it to realize how non-instrusive it is.
#155
#156
I hear these all the time in traffic and I say to myself, “that poor starter”. And these are on cars with most likely low compression. I hate having to make multiple starts just because it’s not the easiest job a component has in the entire vehicle, I couldn’t imagine just being in 20 minutes of bumper to bumper traffic and what kind of wear that is on a car equipped with this feature.
#157
It is cold engine starts that cause engine wear because of the initial lack of lubrication and cold oil. Start/stop systems don't start operating until oil is up to temp and covering all moving parts. During the brief engine stops there is plenty of warm oil lubricating all surfaces, and it causes no more wear than an idling engine. As far as starter wear is concerned, you don't even hear the starter turn during a start/stop restart. It is entirely different from a cold start, and starts are instant. Just wiggle your foot a little on the brake pedal and boom, engine is started.
With regard to the "annoyance" factor, most folks get used to it and forget about it. As I said way up somewhere in this thread, when I first experienced vehicles with them about 5 years ago, I was a little annoyed and turned them off. Slowly but surely, I started leaving it on to experiment, and now I leave it on all the time because I have so much completely positive experience with them in 3 different vehicles and now appreciate the technology.
Also BTW, Jaguar F-Types have it on the high-compression, supercharged engines in all models.
#158
#159
How long before California distinguishes / tests emissions immediately after a start-stop cycle given the frequency of these cycles? I’m betting there’s some cost in emissions that OEM’s would acknowledge, but are not now required to defend in lieu of better gas mileage. Get ready to bend over some more...
#160
Early systems were crap. Cheap systems are crap. Not a big surprise.
I was in the modestly priced flagship CUV from a major OEM all day today. It had start stop. The only inclination I had to shut off the system was that it was directly affecting the conditions for some of my testing. Outside of that, it was of no notice. Half the time I didn't even realize it working. It took me an hour in the car to even realize it was functional, since most of our prototypes are so broken it rarely activates without fighting it to.
JerryU (02-11-2019)
