Gen VI engine based on XV8 dual-cam in block concept?
Well, another way to look at it, two valve springs pressing on one lifter is potentially more load than a 1:1 relationship. Who knows?
Or, the two valves are slightly out of phase of each other to induce a swirl effect?
Overall, definitely interested to hear more about this engine if it is the one in the ME. Could also explain the rumored .1L increase in displacement, a basically entirely new engine. Which now that I "say" that outloud, why would they call it the LT2 and not something different? I'd invision an LT2 to be a derivative of the LT1. But if this has 75 degree banks, all new valve train design, etc... it wouldn't be an evolution of the LT1.
Interesting idea. Differential valve lift to induce a swirl effect. I wonder if anyone here can tell if that's happening based on the cam lobes we can see.
Received 1,817 Likes
And I agree that if it was an entirely new engine, it probably wouldn't continue with the LT moniker. A second in-block cam could be done with little more than machining some mounting pads into the lifter valley, bolting in a second cam support structure, and drilling some additional pushrod hole in the head (if ports and water jackets don't get in the way).
Two smaller intake valves can probably be operated at much higher rpms, than one large one.
Zaro Tundov (04-30-2019)
Interior photo suggests a 6500rpm redline. 3500 marks the top of the tachometer, so it reads to 7000rpm and the last 500 are probably past redline. Pretty much expected for a pushrod engine.
Good call making this a separate thread. I immediately noticed the massive 2 gerotor oil pump in the thread dissecting the marketing video. I can't think of anything a 2nd timing chain would be for other than another camshaft. Neat stuff... very curious what we learn.
Yeah wouldn't make much sense to chain drive those. DI fuel pump works off cam lobe just fine (primary being electric) and, if anything, the water pump may go electric.
Any chance it's a 4V OHV motor? twin cam in block, 4V head w/o the bulkiness of traditional DOHC motors?
Also, note the damper has provisions for 2 belts. Why would you need that if the car is going to be NA or turbo?
It's the top right accessory. Top left is water pump, bottom left is alternator, bottom right is AC compressor.
Edit: another possibility.
The LT2 is still a two valve per cylinder engine, but with two cams in block to permit independent phasing of intake and exhaust.
The bottom cam has two intake profiles of different lift and duration, one profile for low rpm cruising, the other profile for high output. Pushrods follow each lobe, but by using the DFM system's solenoid-controlled hydraulic valve lifters only one pushrod is actuated at a time, or neither if DFM disables the cylinder. The intake valve rocker would be a triangular piece with the valve at one vertex and each pushrod at the others, so the valve could be operated by whichever pushrod is active.
The exhaust could be simply 8 actuators and pushrods for a total of 24 pushrods. The maximum in use at any given time would be 16 pushrods.
Such a design exploits the already developed solenoid-controlled hydraulic pushrod lifters for the DFM system to keep costs low.
Mikec7z (04-30-2019)
Well this is interesting.
If this indeed was an XV8 style engine, and LT2 exists, I think LT2 is improved LT1, and this engine is higher up? Z06 perhaps?
Front lift pump would be electric rather than belt driven. Especially if it's an optional system.
But that mystery pulley is too big to be an idler. It almost looks like it's got a magnetic clutch too. Maybe some kind of auxiliary cooling pump?
I'm stumped. I thought at first it could be related to a 48V mild hybrid system but it doesn't look like any of the motor generator units I've seen and there's already an alternator.
#33
This fun.
This is an example of how much stuff GM has "on the shelf" from which they can choose to accomplish their goal. They can mix and match from technologies that they have tested and are ready to develop for production.
There definitely is something going on with the NA engine that is not obvious. For example, what happened to make the engine a 6.3 instead of 6.2?
IMO, 75 degrees is not likely. Neither is three valves.
But I really don't know what GM is telling us with this photo, especially as we can compare the same view to the new 6.6. That same photo angle was not an accident.
The plot thickens. I love it.
Not to be a wet blanket, but there is a difference between brain storming and choosing. I'm sure the engineers had a ball brainstorming but at some point they had to start eliminating alternatives and make choices.
That would have been the meeting to attend!
When choices were made and directions were set.
The following 3 users liked this post by Kodiak Bear:
#34
Most dual overhead cam motors, designed with longevity in mind, aren't revving much beyond 6500 rpm anyway. Might as well keep weight and bulk down by using a pushrod motor, since the high rpm advantages of using overhead cams are not realized.
#37
RapidC84B (05-01-2019)
#38
Yes, it can rev that high, but it makes peak power between 6500 and 6800 rpm (easily attainable with pushrods), so the high-revving advantages of overhead cams aren't really coming into play.
The Ford Coyote 5.0 V8 can rev to 7500, but makes peak power at a measly 6500, about where a pushrod LT4 does.
So the overhead cams in these engines are little more than placebo effect, carrying the disadvantages of increased weight and dimensions.
#39
^Not sure it is just "placebo". Up to this point, the only real way to do variable valve timing (especially for both intake and exhaust separately) has been DOHC. So DOHC is about more than just RPM.
