Convertible top storage area
It appears that when the Convertible Top is retracted, it is stored above the engine compartment. When the top is up, the area where the top is stored is empty. To work on the engine, this area must be accessed without lowering the top. I was wondering if this area could also be used for additional cargo storage. If it is, than the convertible would have more storage area than the coupe making it more desirable. Hasn't anyone addressed this issue at any of the reveals?
ideal for a pizza
Received 4,116 Likes
2020 C8 of the Year Finalist - Unmodified
Alternative use:
I would not store anything. It slips into the gearing and you are screwed
Dumbell2 (11-05-2019)
Thanks for the picture. It looks like it could be used for additional storage. Third Party vendors could offer a simple boxed section to keep items form entering the gear area. I know I could create a simple barrier that would contain items which would have tabs that could slide under the engine cover. The convertible is looking better and better for me all the time. All I need is the Z06 version and I am a buyer ...
Since I am interested in a Z06 version, if they decide on supercharging the Z06, it would take up some of this area making the availability of a Z06 convertible less likely ...
jcapps (11-05-2019)
Received 5,309 Likes
Received 11,606 Likes
I agree the Pizza comment was a funny comment but if you really look at it, there is more depth there than you realize. The actual depth you have will hold the folded top and is probably at least 10 inches deep by the width and length of the top.. That's good enough for a couple of laptops and some clothing. Will have to see it in person to know for sure.
JockItch (11-05-2019)
KombatKing (11-09-2019)
How in the hell does it make sense to try to store stuff in there when you've got two other relatively large areas that are actually meant for storing stuff? Maybe someone can build a little bin to sit on top of the engine in the coupe too.
In the past, convertibles made this choir even more difficult. With the C8 design, the engineers were clever enough to create a design that provides storage space at least the equal to the coupe. However, we did lose 2.5 cubic feet of storage when compared to the previous generations. If there is a way to get some of this 2.5 cu ft of lost storage I am game for it.
Excellent question ... If it warm enough, it would make an excellent area to store several Pizzas ... I am sure you don't want to store your Banana Split there .. All joking aside, not having seen the convertible in person I am not sure what material is used for the top's headliner. If its cloth or canvas, I am sure GM took this into account and protects it from any heat damage. If it is cloth, canvas or plastic, I am sure the fine engineers at GM took this into account and provided enough insulation to avoid damage. Hence clothing, brief cases or even small suit cases should survive without any ill effects. I would hesitate to store any decorative candles there however.
Last edited by Steve Garrett; 11-08-2019 at 12:32 PM. Reason: Merged Posts - Please use the Multi-Quote button when responding to more than one person.
Originally, I was going to order the C8 Convertible, however after seeing it I have changed my mind. Several reason, I really like the look of it with the top down, but I thought the top was going to retract and rest between the front passenger area and engine compartment, thus still allowing for outside engine visibility. Now that’s not the case, I don’t think there is a $7,500 benefit. I’m just going to wait until some form of the widebody comes out, either the ZO6 or Grand Sport. Your thoughts?
For me the vert will be worth it. I take the top off whenever practical and don't care whether the engine is visible or not.
bdskro (11-08-2019)
