Observation on C8 Spring Mountain
Trying to infer a car's capability based on tire noise and nanny intrusion from a novice driver is just silly.
Second, if the C8 understeer it is at 9.5/10ths. No one is doing that on a back country road unless they are asking for trouble. Spirited driving (as anyone would describe it) in a car like this is literally 6/10ths of the car’s capability and there would be no meaningful understeer issue.
Unless the PS4S they use on the Corvette is a brand new, beholden formulation JUST for the Corvette, this statement doesn't make any sense. The PS4S does not squeal more than the Super Sport, and it would make zero sense for Michelin to provide the GM team with an inferior compound just for the C8.
You are also correct that the last 2 generation of Michelins have dual compounds for the tread, the outer tread designed for dry handling and inner tread designed for wet handling. That's why it's been winning a ton of head to head battles against the best of Extreme Summer tires, in that it sacrifices NONE of the dry handling capabilities while maintains some of the best wet handling characteristics of any tires. The PS4S is suppose to take what the Pilot Super Sport did so well and dial it up to 11.
If I can only have 1 set of tires on my car, ANY car, it would be the PS4S since I live in an area where dropping down to 50 degrees during any time of the day/night would be considered "freezing." Anyone here thinking that the PS4S is just a marginal improvement over the PSS is smoking crack, IMO. It's dry grip levels are closer to Cup 2s than it is to PSSes from what we've seen. And frankly, when I used to work in the tire industry, we benchmarked our best tires against the PSS and even THAT tire blew me away for a street tire. At that time, short of R-comps, the PSS had grip levels in the dry AND wet that few other tires on the market can match.
With 10 year's worth of development the PS4S is more a quantum leap than an evolutionary design off of the PSS if you ask me.
https://www.corvetteforum.com/articl...y-that-good/2/
Link directly to that particular video:
https://www.youtube.com/watch?time_c...ature=emb_logo
12.55 is where the get-off is. He has fallen way behind the lead car at this point, and without being able to see and take your cues from the lead car, or having had enough time to memorize the track, it's easy to misjudge a corner. In this case, he got hard on the brakes during the corner, which isn't great for steering control. Would he have made the corner if he hadn't gotten hard on the brakes? I can't tell.
Keep an eye on the steering angle display on some of the slower corners. In fact, keep an eye on that gauge on screen as much as you can. Pay attention on how the pro dials in an initial turn-in angle, and then all of a sudden dials in a lot more steering angle on some of the turns.
https://www.youtube.com/watch?v=3AoTrYwLQxE
