Daily production numbers
tooold2race (07-07-2020)
Hi Jake 4478 here, dealer said built..
true?
true?
zo6 08 (07-07-2020)
palsapp.com
zo6 08 (07-07-2020)
TheSharkGuy (07-08-2020)
#33
First DISCLAIMER, if first shift does not go to 10 hours starting tomorrow and second shift next week, all numbers will be reduced and your VIN will slide even later. If it happens as forecast on the SS, 5150 will enter the PLl LATE on Friday and then com off the PL mid day Tuesday. Don't confuse the columns - I added the beginning and end of VINs coming off the PL for a period (day) inside the Red lines. The column to its left (not in red box) is adding to PL. I will probably remove this column because some ....If this is difficult, wait until you try to deal with the multiple dash screens and controls! It is not at a 6th grade level like IRS forms.
#37
Where is this VIN production estimation chart? A guy posts one on Facebook... same one?
Possibly both of you need SS instruction renewal.
#38
Mike Campbell (07-10-2020)
