Front Lift System fluid reservoir on passenger side
Thanks for the responses. the following from the owners manual is where I saw a reference to turning off the GPS system to disable the lift from reacting to prior pre set locations, Perhaps this only refers to preventing adding any new ones and not preventing it from reacting to any already pre set, however, if the GPS is disabled, it would seem that it would be unable to identify any pre set ones?
." If the vehicle is raised automatically using GPS, it will automatically lower once the vehicle is located about 60 meters (197 feet) from the programmed location. Drivers can disable this function by turning off GPS location through their vehicle Front Lift System will still operate, but only by using the pushbutton command, and the “Auto Lift Location Remembered” confirmation message will not display".
Dave
Dave
the front lift will only activate via the console button instead of automatically using the GPS location.
front lift hydraulic leak
Originally posted by Asterism - "The manual is awkwardly worded. You cant turn off the GPS system, what they mean is you can turn off the auto-lift feature so that
the front lift will only activate via the console button instead of automatically using the GPS location".
Thanks for the info, since my goal is to turn off the "automatic lift feature" and will not use the manual button until the leak is fixed and you mention turning off the auto feature, - how is the auto feature turned off?
Thanks in advance for your help.
Dave
Dave
Received 1,530 Likes
Unmodified C8 of the Year 2021 Finalist
I hope you guys will keep the rest of us waiting on our cars up to date as new information becomes available.
@68roadster Thanks for creating this thread and for getting the title changed, as that will help people keep track of this issue!
Tin-can (03-05-2021)
FWIW, I'm not so sure that the "Slit" is not what the car came with. I discovered my leak when my car had about 400 miles on it. At first, I thought, maybe, the cap simply wasn't sealed tight enough. I had some .080 gasket material in my tool box and made an additonal gasket to accompany the existing one. The cap then sealed really tight and I completely dried the area with paper towels. I then drove the car and used the lift multiple times and upon return, I still had a pretty good leak. I pulled the cap and discovered fluid had made it's way through the slit and blew out the small channel that is in the cap itself. The cap is designed to allow air pressure to escape as the fluid returns to the resevoir when the lift returns to ride height. I thought the slit was too large and was the reason fluid was escaping. I called my dealer and had them order me a cap as I wanted to see if the "Slit" was suppose to be that size???? When the dealer received the new cap, I took my car over and we compared the new cap with the existing one. While the caps were the same, the new one's diaphram did NOT have a "Slit" but a small "Pin Hole" with what looks like a slightly raised donut circling the hole. My car was actually parked out front of the dealership when I compared the two diaphrams with one of their service writers. They thought the same thing as I and that the slit was causing the fluid leak. I can tell you without a doubt that is/was the issue as the new diaphram took care of things. It's interesting to note that when I ordered my cap, the dealer was showing that none were available. The new cap arrived in less than a week and the parts guy told me that GM was now showing over a hundred in stock???? It could be they re-designed the diaphram knowing this issues and as I have said previously, they will warranty them on a "Repair/Replace as needed basis. Another side note is that when I went in to pick up the new cap, they told me the invoice came in as a "No Charge" and there was no cost to me either. I'm the one that suggested to the service writer that they file a warranty claim as a formality and a way to document my car and the issue it was having. My hope was that eventually a TSB would be issued....wishfull thinking I guess.
Interesting! Having to constantly deal with this issue would drastically reduce the benefit and enjoyment of having Front Lift, so hopefully it was a defect they've fixed permanently. For anyone who lives in an area that requires the Front Lift system--to get in and out of their driveway, for instance--it could make the difference between buying a C8, and not.
Received 5,238 Likes
It's okay... GM never used a vented-seal before.
I'm surprised there is even a vent hole. Most modern brake reservoirs have a diaphragm to allow for the fluid displacement and don't have a vent hole. Brake fluid is hydroscopic and a vent hole allows some moisture to enter.
But the lift probably requires more fluid displacement during actuation than a brake or clutch application. That's probably why they are having problems with this.
Close up of the air pressure relief channel...or air intake.
Original diaphram with "slit" as it comes from the factory...My new diaphram has a similar, but round, small ring/donut with a pin hole in the center...no slits.
The"Slit" when pressure is applied from the backside and how large it actually is. There is also a smaller slit 90 degrees to the larger one if you look closely
The spot at 12 o'clock is where the channel clearly vents to the outside edge of the diaphram. While this is the original cap and diaphram, the new one has a round ring with a pin hole instead of an oval ring and a cross slit. As one can see, there is no real visible sign of the slit when no pressure is supplied for the reverse side. The slit is simply too large and allows fluid to be expelled when the system is in operation. The replacement cap and diaphram resolves the issue.
The following 11 users liked this post by MAD Matt:
68roadster (01-11-2021),
Bigredwing (01-10-2021),
blkvet6 (01-14-2021),
bluan (01-10-2021),
Broken Halo (01-10-2021),
and 6 others liked this post.
I have a feeling that due to a higher volume of fluid transfer, the diaphram wasn't doing the job. The resevoir is also quite large considering, when full, the fluid level only takes up half the volume. This is the first that I have seen of any kind of brake fluid resevoir that has a vent channel along with a vented diaphram. So folks can get a better idea of what we are all talking about, I've have included a few additional pics....
Thanks Matt for all the info here! Like everyone else, I'll be looking out for the potential leak. One question though, based on what you said: the slit caused the fluid to overflow through it and caused leak, but the new cap has a pinhole on it, so wouldn't the pressure also push the fluid though the hole as well? If so, it's something else in the new design that stopped the leak, not the pinhole, right?
#33
#34
Question though: Why does the fluid come out if it doesn’t reach that level in the reservoir, gravity and all? Is it sloshing about? Would some type of vertical extension work better from the top of the cap? How about dirt ingress?
#35
CZS (01-11-2021)
#36
@MAD Matt Thanks for updating with better photos!
Between this issue and water accumulating in the front shock towers, there are things I'll want to monitor regularly for a while after I first take delivery of my C8. I know some people have accidentally broken tabs off at least one of the three plastic covers while removing them to get into this area, and those parts may not be terribly robust or stand up well to repeated manipulation, so some questions come to mind.
1. Do these covers do anything other than dress up the area behind the frunk?
2. Is there any reason one couldn't drive with the three covers off the car until it's determined that all issues there are resolved?
3. If the Front Lift were operated with the plastic covers removed, could any of the fluid get onto the carpet in the frunk if the cap leaks?
#37
Received 1,103 Likes
Modified C8 of the Year 2021 Winner
See answers in bold below:
1. Do these covers do anything other than dress up the area behind the frunk? Not really - they cover up the sides, battery etc.
2. Is there any reason one couldn't drive with the three covers off the car until it's determined that all issues there are resolved? I just discovered my leak this past weekend and am driving with all three covers off.
3. If the Front Lift were operated with the plastic covers removed, could any of the fluid get onto the carpet in the frunk if the cap leaks? No, it drains into the area behind the frunk tub.
#38
front lift
In response to Bear's questions:
I, as stated to my earlier comments in this thread, have the same leak situation.
I have turned off the automatic lift feature until my replacement cap comes in.
I have removed the plastic covering the reservoir area until I re- install after new cap - this is just an appearance feature - I have been driving the car with it removed and no issues.
Since the fluid leaks downward from under the cap it would seem that it could not spray outward so as to get in the trunk area, probably continue to still leak downward. If anyone with this problem can do without the lift for a few days, just turn the GPS auto function off function off - you can still use it manually if you have to.
#39
I checked my 2021 and it also was starting to leak. I have only used the lift like 4 times since I got the car. I checked the cap and have the slit in the diaphragm just like the previous pics.
They need to put out a recall for this. People won't know it's leaking unless they check or enough fluid leaks and the system is inoperable. By that time there is a huge mess.
