Solved The Flooded Front Shock Tower issue
No need to spend tons of money on stupid products. I installed weather stripping on the battery access panel and it totally eliminated the water intrusion 100%. Simply apply sponge rubber weather stripping to both the car and the panel and it’s done. See photos. It’s the same type of weather strip GM uses on the other side of the panel and the rear hatch. I had my detail shop flood the area under pressure and not a drop came in to the towers. Cost under $5
The following 17 users liked this post by MagicGlass:
ArmchairArchitect (01-25-2021),
Blade2382 (01-24-2021),
blkvet6 (01-25-2021),
bluan (01-25-2021),
CorvetteBrent (01-26-2021),
and 12 others liked this post.
For those that have sent me PMs, The weather stripping goes on the under side edge of the battery cover panel that goes closest to the windshield side carefully going around the front of the push clips. I also installed a secondary strip on the plastic edging the panel sits on just below the windshield for extra protection. The photos I posted are the only ones I have right now. Carefully look at each photo for placement of the weather strip.
The following 3 users liked this post by MagicGlass:
Wouldn’t it be easier to just buy the plastic covers for $55?
The following 2 users liked this post by John510:
Jacques Albrecht (01-24-2021),
onebadjon (01-25-2021)
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Sticky
I nominate this thread as a Sticky !
The following 5 users liked this post by MikeyTX:
B747VET (02-21-2021),
ea327 (01-25-2021),
rsl2715 (02-21-2021),
YWZ08 (02-01-2021)
NCM Lifetime Member
@Hillslam You can find it at Lowes, Home Depot, Ace Hwd, etc. It's basically weather striping for windows. Has adhesive on one side. Comes in different widths and thicknesses.
The following 4 users liked this post by MikeyTX:
MagicGlass (01-24-2021),
Even water doesn't like Zeus Bronze......
carriccp (01-24-2021)
The Consigliere
Received 5,477 Likes
Red Mist Rulz (01-28-2021)
Received 19,718 Likes
'20-'21-'22-'23-'24
Good, simple and inexpensive way to keep water out of that area. Thanks for posting your solution.
Received 11,810 Likes
Too bad that's not where the water comes in from.
The following 2 users liked this post by MagicGlass:
MikeyTX (01-25-2021)
No that marking is coming from the underside of the battery cover panel. The battery cover lays on top of that weather strip.
