Sponsored by: Wheel Design
Lowering Z51
Old Mar 8, 2021 | 07:09 AM
MAD Matt's Avatar
MAD Matt
Originally Posted by Endeavor1
Out of curiosity, how long did it take you to complete these?
About a week and a half after waiting on fiberglass to set up, and paint supplies to arrive. Actually only spent an hour or two each day, molding and sanding and....waiting for resin to kick.
Old Mar 8, 2021 | 07:57 AM
ladder13's Avatar
ladder13
Why would anyone lower the car after spending $1995 on E60? Explain.
Old Mar 8, 2021 | 08:19 AM
HotRodBoy's Avatar
HotRodBoy
Modified C8 of the Year 2021 Finalist
That's the beauty about the front lift. You can lower the car by approx. an 1" to eliminate the stock ride height tire to fender gap while still maintaining the flexibility to raise the vehicle during steep driveway slopes, speed bumps or any other lower fascia scuffing situations.
Old Mar 8, 2021 | 08:44 AM
progtp's Avatar
progtp
I lowered my Z51 with magride but no front lift last week. Lowered as far as it would go which was about an inch I think. I'm very happy with the results. Looks better. Handles better and ride quality is very close to stock.
Old Mar 8, 2021 | 09:24 AM
thill444's Avatar
thill444
Originally Posted by Alex M
Front lift and magnetic ride I have
Personally I would not install aftermarket springs then. The MSRC has been specifically programmed with the stock spring rates, one you start installing aftermarket springs you likely will have different spring rates and MSRC will not be optimized for them. At least that's my thought process.
Old Mar 8, 2021 | 09:25 AM
thill444's Avatar
thill444
That looks spot on to me. I would not want to go any lower. Very nice.
4camV8's Avatar
4camV8
Default Conflicting Info Here...
For 2021’s. Some say you must have Z51 to gain the adjustable spring perches while others say Z51 is NOT necessary as long as you have MSRC....
Does anyone know for CERTAIN which is accurate/correct??
Anyone with a 21 who has lowered a NON-Z51 WITH MSRC using only the factory supplied perch adjustment?
(I understand and everyone is in agreement that if you have Front End Lift, you must purchase aftermarket collars to adjust the front)
I’ve yet to order. I prefer a non-Z51 with MSRC but only if I can adjust the ride/close the wheel gap .75-1” or so...
Old Mar 8, 2021 | 12:23 PM
vettebyassociation's Avatar
vettebyassociation
See i thought you could lower a Z51 without mag ride but some in this thread are saying you need it. So I too am confused about what can and can't be lowered with stock hardware
Old Mar 8, 2021 | 02:04 PM
Zymurgy's Avatar
Zymurgy
Moderator
Originally Posted by rrsperry
This is incorrect. You need to have Z51 to have the adjustable coilover shocks. MRC makes no difference at all... I have a 2021 Z51 with MRC and ALL Z51's have adjustable shocks. (again except if you have the front lift. then you need the collars.)
For 2021, MSRC without Z51 gives you the mag shocks (and associated adjustable spring perches) and nothing ,more. No bigger brakes, no eLSD, no PTM, no additional cooling, etc.
This was confirmed by the Corvette team.
Old Mar 8, 2021 | 02:50 PM
4camV8's Avatar
4camV8
Default Perfect.
Exactly what I needed to know prior to ordering. Thanks!
Old Mar 8, 2021 | 03:44 PM
ladder13's Avatar
ladder13
So you get the 1 inch back that you lowered plus the 1.8 inch that the front lift gives you? 2.8 inches from lowered height?
Old Mar 8, 2021 | 05:00 PM
ssv3's Avatar
ssv3
Nice!! A couple of questions please. I have MSRC with the front lift and I'm anticipating on lowering also depending how the car looks after I get my wheels.
Are those Strasse wheels?
Are those 19/20 or 20/21. I have SM5RT Deep Concave FS 20/21 set nearing completion and curious about your set up.
TIA
Originally Posted by dgerstel
I have front lift and magnetic ride, lowered 1" in front and about 3/4" in rear with Cicio Front End Lowering Kit.
Old Mar 8, 2021 | 08:22 PM
  #33
carriccp's Avatar
carriccp
If you lower the car 1" and the lift provides 1.8", you would be 0.8" higher than stock when lifted...
Old Mar 8, 2021 | 09:29 PM
  #34
ladder13's Avatar
ladder13
I really knew the answer.
Thats an expensive .8 inch, and defeats the whole purpose of the lift in the first place. You lower a car, then spend almost $2000 to lift it .8 inch? I thought people bought the lift to eliminate, mostly, if not totally, scraping.
I just don’t see the reward. Is .8 inch going to help much?
Old Mar 11, 2021 | 07:22 PM
  #35
HotRodBoy's Avatar
HotRodBoy
It certainly does for me with my driveway ramp angle. No issues after lowering the car and using the front end lift.
Old Mar 11, 2021 | 08:25 PM
  #36
Billy20's Avatar
Billy20
This is on eibach 1in lowering springs...coils at stock height....could go down another .75 in
Old Mar 11, 2021 | 08:50 PM
  #37
4camV8's Avatar
4camV8
Default Looks perfect!
How’s the ride and handling compared to the stock springs?
To Lowering Z51
Old Mar 14, 2021 | 12:14 AM
  #38
canuck9's Avatar
canuck9
Are you sure? Part of why I was leaning towards Z51 was so I could easily lower it...this would be great if indeed true...just haven’t seen this anywhere else.
Old Mar 14, 2021 | 01:23 AM
  #39
shiumai's Avatar
shiumai
Modified C8 of the Year 2021 Winner
Anyone have rubbing issues after lowering during spirited driving or hitting dips?
Old Mar 14, 2021 | 01:07 PM
  #40
progtp's Avatar
progtp
I haven’t had any rubbing issues at all since lowering while driving on the roads. The only issue is a little less clearance on driveways and speed bumps but I’m willing to live with that.
