Sponsored by: Wheel Design
Lowering Z51
Old Mar 7, 2021 | 02:06 PM
Alex M's Avatar
Alex M
Default Lowering Z51
I am checking out the lowering options on the Z51. I see the tool available to lower the z51 coilovers .7” inches.
Do people generally go this route or swap out and do lowering springs?
pros/cons?
Popular Reply
Mar 7, 2021, 07:57 PM
dgerstel's Avatar
dgerstel
I have front lift and magnetic ride, lowered 1" in front and about 3/4" in rear with Cicio Front End Lowering Kit.
Old Mar 7, 2021 | 04:49 PM
rrsperry's Avatar
rrsperry
If you have front lift you are very limited. But I’m not really seeing a need to massively lower my Z51. 1/2” will be perfect.
Old Mar 7, 2021 | 04:54 PM
thill444's Avatar
thill444
pros/cons?
Do you have magnetic ride?
Old Mar 7, 2021 | 05:23 PM
Zymurgy's Avatar
Zymurgy
Moderator
You must have MSRC to have the adjustable spring perches. If you have the front lift and MSRC, only the rear has the adjustable spring perches. No MSRC, no adjustable spring perches.
Old Mar 7, 2021 | 06:17 PM
Alex M's Avatar
Alex M
Front lift and magnetic ride I have
Old Mar 7, 2021 | 06:24 PM
Zymurgy's Avatar
Zymurgy
Moderator
So, with the front lift you don't have the adjustable spring perches on the front. You'll have to go with something like Paragon Lowering Collars.
Old Mar 7, 2021 | 07:57 PM
dgerstel's Avatar
dgerstel
Old Mar 7, 2021 | 08:10 PM
HotRodBoy's Avatar
HotRodBoy
Modified C8 of the Year 2021 Finalist
I just lowered mine this weekend with Paragon lowering collars on the front end lift and adjustable in the rear. I'm very happy with the results compared to the stock height....
Still waiting for my back ordered wheels..
Old Mar 7, 2021 | 09:01 PM
MAD Matt's Avatar
MAD Matt
Z51, Mag, Lift...Paragon collars up front, Rears dialed down to factory max along w/ AG 520R's 19/20
Old Mar 7, 2021 | 09:09 PM
Redgrandsport17's Avatar
Redgrandsport17
That looks amazing. Not to get off topic but what is on your front bumper? Are those canards? Where did you get those from?
Old Mar 7, 2021 | 09:18 PM
MAD Matt's Avatar
MAD Matt
Yes, they are front canards/dive planes. I handcrafted them from fiberglass replicating the shapes in the front splitter...
Drivers side....Fabricating opposite sides is rather difficult but not impossible using measurements for angles and contour gauges for shapes....measure ten times...cut once.
The design follows the contours of the body while hugging the car...I shot them with Carbon Flash base coat/clear coat to match the rest of the trim on the car. You can also see how I picked up on some of the shapes from the grill inserts and front splitter...
Old Mar 7, 2021 | 09:23 PM
Endeavor1's Avatar
Endeavor1
7th Gear
^^^ very nice addition and great craftsmanship!!!
Old Mar 7, 2021 | 09:26 PM
MAD Matt's Avatar
MAD Matt
Thanks!
Old Mar 7, 2021 | 09:34 PM
NoMatter's Avatar
NoMatter
What’s Next
Many props to you. I’ve always loved canards myself plus functional.
Old Mar 7, 2021 | 10:01 PM
Endeavor1's Avatar
Endeavor1
7th Gear
Out of curiosity, how long did it take you to complete these?
Old Mar 7, 2021 | 11:12 PM
carriccp's Avatar
carriccp
I thought MSRC has no impact on the threaded shock collars, and that was a Z51 deal...
Old Mar 7, 2021 | 11:18 PM
colossians323's Avatar
colossians323
Looks good. I can't tell from your photo if the mbz is a 63s or not if so, have you broken the 500 miles on your vette to compare two? I have the 63s, but unfortunately have not hit 500 miles yet on the vette
To Lowering Z51
Old Mar 7, 2021 | 11:37 PM
Zymurgy's Avatar
Zymurgy
Moderator
Well, yes and no. For 2020 Z51 (with or without MSRC) had the adjustable perches. For 2021, either Z51 (with or without MSRC) or MSRC alone gets you the adjustable perches. In all cases, the front lift eliminates the front perches.
Old Mar 7, 2021 | 11:51 PM
HeadTurner's Avatar
HeadTurner
I have a 2020 Z51 with no MRC and no front lift and lowered my car a around .75 of an inch. Came out great!
Old Mar 8, 2021 | 06:37 AM
rrsperry's Avatar
rrsperry
This is incorrect. You need to have Z51 to have the adjustable coilover shocks. MRC makes no difference at all... I have a 2021 Z51 with MRC and ALL Z51's have adjustable shocks. (again except if you have the front lift. then you need the collars.)
