Snuggy Seats
Snuggy Seats
Anyone else find the seats way too snug up top? I went with the base GT1 seats and 2LT. The hip bolster on the left side feels a bit tight (just like it did in my C7 but I fixed that problem with a softer foam insert) but I can't believe how tight the upper part of the seat feels on my ribs!! I'm 5'10" and 205 and work out but I'm no Superman and I find the seat back really uncomfortable up top.
It is a well-built engineering marvel but if i can't be comfortable in it it may be up for sale. I find my 2019 Z06 2LT seats so much more comfortable.
Outside of taking a blow torch to the plastic seat back to widen it (J/K), any suggestions??
Received 4,138 Likes
Before you break out the torch, if the tightness is in the foam, I'd consider having an upholstery shop soften it up. If you drill a grid of holes in the foam pad in the firm area, it will soften it up without ruining the shape. This technique works well on the bottom bolsters if they're too firm
Sorry if I wasn't clear in my original post. My concern isn't with the padding in the bolsters - it is with the relative narrowness of the upper sides of the seat where they contact the upper body. The plastic shell on which the seat is built seems too narrow to me and I have no idea how this can be remedied or how the upper part of the seat can be made more comfortable.
Rexvaughn (03-07-2023)
I also have GT1 seats, I’m 5’9 about 190 lbs and they fit me just fine. Very, very comfortable I would say. I have no idea exactly how wide my shoulders are though, but my body type is more broad than narrow. Good luck on finding a fix to make them more comfortable for you.
I have a 3LT interior and I’m not a small person and I find the seats very comfortable. Now the seats can be re worked by a trim shop and widened. My neighbor who was President and CEO of McDonalds (Ed Rensi) at the time had his ZR1 seats flattened and widened because he weighed close to 350 pounds and they turned out quite nice.
Received 2,496 Likes
St. Jude Donor '15
"In honor of jpee"
You appear to be a long way from the Toronto metro where there might be quite a few upholstery shops, but that doesn't mean you can't go there or that your own nearby area doesn't have a good one, too.
Good luck.
Received 5,299 Likes
It's a sports car... not everyone will necessarily fit.
Don’t the GT1 seats in the 2LT have adjustable upper support? When I drove the 2LT with the GT1 seats at the BG track, the instructor suggested that I might be more comfortable moving them out. He noticed they were pressing in on my ribs. The GT1 seats in the 1LT aren’t adjustable.
After doing some research I realized it was more about torso height than my weight / size. The narrowest part of the seat was aligned with the widest part of my rib cage. A few other folks of similar proportions reported similar discomfort.
I ended up experimenting with the seat configuration, and basically found a position where the seat back was more upright that usual for me (I offset that by tilting the seat back as well) and it moved the narrow part away from where it was squeezing me. After driving a month or so in that position, it took a little getting used to, now it’s fine.
Hope that helps.
LuckyGuy (05-12-2021)
