Chevy will not honor warranty for lowered c8
I have a 2021 C8 with z51, mag ride, and front lift. 10 months ago I got a lowering kit (Paragon) and had it professionally installed. Everything worked perfectly, my lift engages in my driveway so I probably used it 100 times since I installed the kit,
About 4 weeks ago I started to get warning message to service the lift and also messages that the lift was inoperable. I took it into my chevy dealership and, after a long waiting period, I was told this morning that lowering the car voided the suspension warranty and they would not do anything on the lift unless I restored the car back to its stock height.
I am wondering if anyone else is having any issues with the lift system either with a stock height or a lowered car, and also does anyone have any other experiences with Chevy and warranty issues for lowered cars.
Thank you.
Marc
Thank you.
Marc
Popular Reply
04-13-2022, 02:35 PM
"dealers will always look for a way out." - Last I heard (about 5 minutes ago) dealers love warranty work. They get paid by the manufacturer, not the owner. Easy money. I'm guessing the dealer doesn't have a qualified tech and is afraid of problems the tech could cause by working on something he's not familiar with. Take it to another dealer. No need to mention the 1" collars. Butt that's just me.
The following 10 users liked this post by oldC5:
befree2spin (08-03-2022),
BlueSteel07 (04-17-2022),
Display333 (04-18-2022),
JD'S WHITE 93 (04-16-2022),
Landru (04-23-2024),
and 5 others liked this post.
Man that sucks, but makes sense! Warranties are tricky, and dealers will always look for a way out. Will be skipping lowering mine now.
To answer your question, no front lift issues here, used probably 50 times on a 300+ mile car.
Thank you.
Marc
Thank you.
Marc
The following 4 users liked this post by C8Rob:
Thank you.
Marc
Thank you.
Marc
Regardless, I'd first try taking it to another dealership if that's an option.
If not, then just remove the springs and reinstall the OEM ones and get things fixed.
ArmchairArchitect (04-13-2022)
I’m not surprised at all.
That's a thought break, Sorry. Unfortunately, that's a risk of making moderations to your vehicle.
The following 6 users liked this post by Kevin A Jones:
4thC4at60 (04-13-2022),
Fast Dawg (04-14-2022),
Wife said I could (08-03-2022),
ZR1Bob (04-17-2022),
and 1 others liked this post.
The following 11 users liked this post by PopsC8:
ArmchairArchitect (04-13-2022),
Geezer1 (04-14-2022),
Greg00Coupe (08-04-2022),
Kracka (04-17-2022),
Lazzz (04-15-2022),
and 6 others liked this post.
The bolded doesn't make any sense. If the warranty is voided, then returning it to stock should still mean a voided warranty. But if they're willing to service it with the OEM springs installed, even if problem was caused when lowering springs were installed, then the warranty wasn't actually voided.
I work at a dealer and they LOVE warranty work. It usually pays way more than it takes to do the job.
As mentioned above I don't think they have the skills to tackle the issue. Try another dealer.
The following 10 users liked this post by progtp:
DNAST1 (04-13-2022),
dohabandit (04-16-2022),
JoeB3 (04-18-2022),
I agree the problem isn't because dealers don't like warranty work. However, for the dealer to get reimbursed for warranty work, the repair has to be approved by GM. It is quite possible that the tech contacted the tech line for support and the subject came up the the car was lowered. At that point GM could have put the kibosh on warranty coverage.
You're definitely in a pickle, since Chevrolet now has a GMVIS report on your car, which is a permanent record. Good luck on whatever you decide to do. 👍
The following 4 users liked this post by Skid Row Joe:
Regarding the idea that you take it to another dealer, I believe it is likely a reason code for not covering a modified lift has already been entered on the computer applicable to this vehicle VIN. They know everything, such as when I am 100 miles past a scheduled oil change or something small like that - as I get reminder notifications via email.
Next dealer agreeing to work on it may not be allowed to cover it.
Anybody have thoughts about this?
BTW I lowered my car and have the lift and zero problems so far at 21, 000 miles. I believe the look of the stance makes it a worthwhile mod.
Yes, this is exactly what happened in this case. The dealership here in Austin reached out to GM C8 technical support to get approval to replace the lift kit and it was C8 support rejected the work. I volunteered the information about the lowering kit with the caveat that it was done 10 months ago and had worked perfectly many many times but that did not sway them.
The following 2 users liked this post by Skid Row Joe:
DeltaMobile (04-23-2024),
Steeveau (04-15-2022)
Marc
Skid Row Joe (04-13-2022)
