Am I imagining Things?
I don’t ever remember seeing this park indicator here in the corner.
Never Mind I now have bigger fish to fry after the new update. Everything going haywire now. 😡😡😡
Yep, I see it all the time and look for it because the E brake is a button and not some thing that can be readily be seen hidden on the lower dash panel by the drivers left knee. Now you know it's there you will be looking for it.
MacoSnark (07-04-2022)
I noticed that today but I don’t think the brake goes on when you put it in park unless you are on a steep incline.
Hillslam (07-03-2022)
I'd like it if this is actually the case. However, they'd need an option in the settings to not set the EPB after a track session (unless it monitors brake temperature and doesn't engage when too hot).
I guess if it automatically sets after a track session you can immediately release it.
For street use, though, I'd be happy to have it set automatically. I always use it, and the button location is terrible.
The following 2 users liked this post by Red Mist Rulz:
dohabandit (07-02-2022),
hamta (07-02-2022)
I think I saw the same PARK warning light when I restarted my car after having the front end raised on Rhino Ramps.
E-Ray, 3LZ, ZER, LIFT
Received 9,683 Likes
Haven't had an update in months. We'll see if it affects 2020s.
I agree it would be good for street use. But they also need to make it so it automatically releases when the car is shifted out of Park instead of after some throttle is applied.
Red Mist Rulz (07-02-2022)
Does the parking brake now set each time the car is put in Park or was this a one time glitch after the update?
