C8 Transmission Filter
I dont understand. I have an appointment next week but wonder...is this rare, and is it covered under warranty.
Sounds serious to me.
Popular Reply
Did you use your "Free" service for the oil change and transmission filter when you had 5,000 miles? If you did, you will have to pay for the transmission filter change at 7,500 miles and I believe that charge is around $600.00. (There are a few threads on this within these forums. Do a search and you will see what others paid).
Here is a link form a recent post from last week regarding changing the transmission filter too early and than again at the 7,500 mile mark.
https://www.corvetteforum.com/forums...at-7500-a.html
Last edited by David.L; Mar 8, 2023 at 10:43 PM. Reason: Added Link to Previous Discussion
'REPLACE TRANSMISSION FILTER SOON". I'd like to know exactly what it said, the miles when it appeared, and the percent filter life when it appeared.
They confounded the 7500 DCT filter requirement with the much clearer Engine Oil/filter requirement, when the OLM says!
I also agree with RKCRLR that changing the DCT filter at 5000 miles (for whatever reason he changed at 5000) then again at 7500 is irrational BUT meets the GM requirement. Guess he could have "paid for" the engine oil/filter at 5000 miles IF it was OLM driven and at least got the free DCT filter (and flush) at 7500 miles.
I know some have said they must be combined to be free but I sure would have tried to get both covered separately if below 2 years. BUT if the dealer doesn't get reimbursed can't blame him for not doing!
As I said in prior posts need some what ifs from GM!
I deal with a small dealership in a rural town and they did in fact change the oil around 5500 miles for free, but at that time I did not inquired about the filter .
This could go one of two ways. When I take it in the service advisor will see that the car is less than one year old and I am entitled to a free filter.
Orrr they could say we changed the filter for free at 5500 and now you need a new one for ($600. ?)
As you can see, im a rookie when it comes to Corvettes. I just dont want to spend $600 unnecessarily
Bill
Bill
Bill
Either way, good luck with the dealer and hopefully they will take care of you.
You admitted you are a rookie at this. The transmission itself is a $20k item. Don't make a $600 mistake that could cost you thousands down the road. If you don't care about your warranty (5 years for drive train I believe), then by all means, ignore the service requirements. Either way, even if they didn't change the DCT filter at 5000 miles it will most likely be on you unless you argue with the dealer as there is only one free service provided by GM - and you already had one.
https://gm-techlink.com/?p=17254
which says "If a customer elects to have the filter changed before 7,500 miles (12,000 km), it should be changed again at 7,500 miles (12,000 km)."
The article also never says how early must it be to require changing again at 7500 miles.
But, thanks to you , we now have an additional data point - the message to change the filter soon appeared at 7200 miles. The manual says change it as soon as possible after that message appears. So we know 7200 miles is not too soon. But is 5000 too soon? I'm just not sure. I would probably change it again at 7500 (mine was changed at 2500 and I do plan to change it again at 7500). It is not just a warranty issue - there really is wear in debris accumulation between 5000 and 7500 miles according to GM. But if you are comfortable ignoring those statements and rolling past 7500, at least consider that you probably do not want to go a full 22500 more miles before you change it again. Assuming the only issue is DCT filter loading, my guess, using totally made up assumptions, is that if you changed it at 5000 miles on the odometer, you might be able to go an additional 17500 miles from the filter change at 5000 miles (reading 22500 miles on the odometer). That's based on what I think is a worst case assumption about how wear in debris is shed during the 7500 mile transmission break in period. But its not what GM says, and its not what I would do. Its just one extra filter change in the life of the car, why not do it in conservative way.
