C8 Transmission Filter
https://gm-techlink.com/?p=17254
which says "If a customer elects to have the filter changed before 7,500 miles (12,000 km), it should be changed again at 7,500 miles (12,000 km)."
The article also never says how early must it be to require changing again at 7500 miles.
But, thanks to you , we now have an additional data point - the message to change the filter soon appeared at 7200 miles. The manual says change it as soon as possible after that message appears. So we know 7200 miles is not too soon. But is 5000 too soon? I'm just not sure. I would probably change it again at 7500 (mine was changed at 2500 and I do plan to change it again at 7500). It is not just a warranty issue - there really is wear in debris accumulation between 5000 and 7500 miles according to GM. But if you are comfortable ignoring those statements and rolling past 7500, at least consider that you probably do not want to go a full 22500 more miles before you change it again. Assuming the only issue is DCT filter loading, my guess, using totally made up assumptions, is that if you changed it at 5000 miles on the odometer, you might be able to go an additional 17500 miles from the filter change at 5000 miles (reading 22500 miles on the odometer). That's based on what I think is a worst case assumption about how wear in debris is shed during the 7500 mile transmission break in period. But its not what GM says, and its not what I would do. Its just one extra filter change in the life of the car, why not do it in conservative way.
Is the "free" DCT filter change still available to me? Is there a time limit, even if the mileage is still below 7500? I'll be at least a year or more getting to 7500.
Any real-world experiences would be most appreciated!
That last part suggests that there is a good chance that warranty claim will be denied if the maintenance schedule was not followed.
Plus looking at the Owner's Manual as ALL C8's whatever year, at year 3 regardless of miles you MUST have all 11 quarts of DCT fluid changed. Thought heck I'll have about ~10,000 miles and ~6000 on that 1st year changed filter. Good time to have the DCT Filter changed again. Not exactly GM's 7500 miles but for me good enough to make a case if needed. Also good time to have the Dealer Tech change engine oil/filter (as OLM will say to do that,) fill with new DCT fluid AND rather than have ~7 oz of old fluid in the filter and filter housing it will be new fluid.
Discussed with the C8 Corvette tech this past August, year 2 when I paid for just having required engine oil/filter change. He thought good plan. That is all on my dime as the 11-quart change would be. To perform the 11 quart change he has to access the DCT fluid fill plug by removing the aluminum aero panel "shear plate" anyway so why not! Suggest as minimum that would be smart. Not perfect but provides some extra DCT protection.
Your Car Your Choice.
Here are some pics:
To access the DCT Fluid fill plug Tech must remove the aluminum, aero Panel (GM also calls shear plate as it provides a structural function.)
Pic of plate removed when tech changed my DCT filer year 1 with ~3000 miles
GM says ~ 0.2 Liters = 7 oz DCT fluid in filer housing. To access the DCT fluid fill plug (and filter) the aero panel must be removed.
PS: I just noticed when I posted this old pic I made ~ 2020 it says: DCT Filter MUST be changed during this 1st Oil Change! Now this is typical GM conflicting statements, both in the Owner's Manual and elsewhere. If I am ever questioned for the 6 months I'll have between when I reached 7500 miles on my C8 (just recently) and Next August when I'll have the DCT filter changed again I'll just print this pic and say, just following what was published!
BTW my Tech would never question it would be GM questioning the dealer!
I contacted Chevrolet Customer Support via their messaging system and asked them if I needed to change the DCT filter again at 7500 miles. They said I was good untill the next schedulred service interval. I took a screenshot of their response and saved it for my records.
If you decide not to have your DCT filter changed again at 7500 miles I recommend you get something in writing from GM stating it is OK.
I have years of experience collaborating with dealerships to include brokering deals where dealerships sold in-house performance parts.
I also have years of experience driving cars and blowing up engines in them lol.
I can tell you that dealerships do not approve or deny warranty claims. That's general motors.
And the absolute first thing that general motors will ask for is the service history on any large ticket drivetrain item like an engine or transmission.
Now they may be willing to give Goodwill and give concessions if you didn't follow the maintenance schedule quite perfectly but the further away you get from it the less and less likely you are to receive any good will.
I changed the engine oil, oil filter and DCT filter at 3000 miles for my peace of mind on my 2021.
At 7300 miles did the change again per GM guidelines. If I have a DCT issue my cars service history record is with in the guidelines.
There has been a significant amount of transmissions that have been replaced over something very simple as debris getting stuck within the valve passages and in the solenoids but unfortunately there is no repair procedure for that other than trying to flush it out and so the entire transmission gets replaced.
For me to simply avoid my car being out of commission for that long and the inconvenience of it I had no issue flushing and replacing the filter early and it was indeed soaked with debris.
For oil changes Corvette has an interesting history on the c7 of in fact getting the initial oil change interval wrong. They actually went back after silicone contamination was found from the adhesives in the dry sump system which is the same system we use and determined that a 500 MI oil dump was required.
Because of their rather poor track record on proactively identifying this as an issue I decided to check my oil quality at 640 MI and low and behold it had visible metals in it as well as silicone contamination.
I definitely am not suggesting that everybody has to do what I did but I am very glad that I did it again mostly out of convenience that I just rather not have to deal with a dealership replacing engines and transmissions. ... As well as the aftermath that can sometimes come with it which is a car that comes back not yet fully ready for the road.
In addition to Techlink, people from the Corvette DCT team also state that if changed early it should be changed again at 7500 miles, two years in a row at Carlisle.
I respect your knowledge and much of what you've posted on the forum, but telling a dealer that "this guy on the Corvette Forum told me I could drive it another 17,500 miles before changing the filter" isn't going to hold much water compared to the direct instructions from GM Techlink.
When assembling the ZZ 502502 engine for my Street Rod they provided a tube of high temp silicone sealant and said use it NOT the "rubber end seals." See pic from instructions.
SIDEBAR
The reason it was probably only for dry sump C7s is that is where the oil foam would go from the pan that GM said might occur with the original oil fil IF the engine was operated at sustained speeds. Then the foam would be sucked into the dry sump tank by the scavenge pump. To get all oil out of the pan it sucks a lot of air as well. In fact foam might be more likely to occur as oil and air go thru the scavenge pump. Then the foam would leave the top of the dry sump tank with the air that was sucked in as well. The air is "burped" thru a hose to the air intake tube.
The wet sump has no such hose. I found the last sentence in that November 24, 2014 bulletin interesting. It said "The oil foam has no effect on engine durability."
Had to cover their *** for not requiring the change on wet sumps or my car where it was NOT required! In fact the issue was that oil foam would condense it the air intake tube and run down to the air filter and drip on the ground. It was that contamination they were trying to avoid.
MY CHECK
The bulletin that came out ~14 months after I got my early C7 Z51 in September 2013. As I had with all my Vettes (and street rod) I changed the oil early ~1000 miles. So I wondered 14 months later when the bulletin came out did I have any issue. Although I did not drive the car at "sustained high speed" I did hit redline in lower gears after break-in (a number of times before the oil change.) I had looked at the incidence of oil foaming and it is common in oil pumps So the oil/air scavenge pump could be a significant source.
I installed an aFe low restriction air intake system that included a larger filter housing, larger oiled cotton filter and different air intake tube. I looked very carefully and not a drop of oil on the OEM filter or air intake tube.
Bill
I just got weird about this car and also wanted to check what was going on inside the engine and perhaps this one out of my three c8s had this issue. Go figure
