C8 Transmission Filter
Bill
GM's wording very clearly states one free service before 2 years or 7500 miles. That neither you nor, apparently, the dealer actually read GM's customer care documentation doesn't obligate GM to provide two free services. That the dealer failed to inform you of that maybe gives you some claim against the dealer.
If the first filter change is at 1500 miles the next filter change should be ........
If the first filter change is at 2500 miles the next filter change should be ........
If the first filter change is at 4500 miles the next filter change should be ........
If the first filter change is at 6000 miles the next filter change should be ........
If the first filter change is at 7500 miles the next filter change should be at 30000 miles. (22500 miles later)
According to some it is:
If the first filter change is at 1500 miles the next filter change should be 7500.
If the first filter change is at 2500 miles the next filter change should be 7500.
If the first filter change is at 4500 miles the next filter change should be 7500.
If the first filter change is at 6000 miles the next filter change should be 7500.
ive had 3 transmissions installed under warranty in my 2020 corvette now at 22k miles
thanks for your interpretations.
id like to see the legal standing of the zone rep trying to tell me my transmission warranty is voided because I changed the filter on the third transmission in this car at 6300 miles instead of 7500 miles as stated in the supposedly Holly grail owners manual since the installation and that’s the reason the transmission failed a forth time and GM isn’t responsible.
every time I had previously happily drove in just fine , then the dealerships changed the filter and the transmission took a dump
use common sense and just change the filter and fluid around the required time and mileage requirement.
only a pin head says it has to be exact
jmo
- You reach 7500 miles end year one and you'll be changing engine oil and DCT filter (with flush.)
- Or if you think you will reach 7500 miles close to end year 2 and can change the DCT filter before the 2 year Max for Free ends.
- That regardless of miles had to replace the 11 quarts of DCT fluid year 3.
- A number of folks posted having early DCT CELs. When the dealer read the CEL failure code to GM Service they were told to perform a flush (not a DCT filter charge in most a cases just a flush.) That takes about 10 minutes with the car connected to the GM Service Computer and engine running. It cycles the many valves and actuators that control shift fork movement for the 8 gears and whatever. Thought, prudent to have that flush done year one as it's required before a DCT filter change. So when the OLM said change engine oil at 12 months and ~3000 miles had both done on GM's dime.
- GM also acknowledged Tremec found some transmission shafts that were not sufficiently clean prior to being installed.
- Also could feel a slight jerkiness when driving at very slow speed as I crawled into my garage. I try, as now, to keep the driver's mirror tip to door wood molding gap about an inch, which assures the harder to judge passenger mirror, has plenty of clarence. After ~1000 miles, as now, it was perfectly smooth. So there was some initial wear on that slipping 1st gear clutch. Has to slip up to ~ 4 mph or the engine would stall!
- Knew year 3 with the 11 quarts of fluid change I would install another new filter. That would be ~two years on the 1st new filter. Would also not have ~7 oz of old fluid and old filter left with that 11 quarts of new fluid. Not a big deal as it's a small percentage but better all new.
- Not exactly when the C8 has 7500 miles BUT about when that 1st year filter will have about 7000 miles.
When I posted an old pic from my file in this Thread I saw one of the GM recommendations I had not noticed. I clearly says perform the 1st maintenance when the Driver's Information Center indicates to change oil. Can't miss those messages that start at about 10% Oil Life Left and say change oil soon. You have to press OK to get rid of message. It continues to post that message every time to start the car, Recall I was down to 5% when I had it done. It will decrease with time change 1/12 per month, or 8%.
It also says clearly, Dual-Clutch Transmission filter MUST be changed during the FIRST oil change! Frankly used that GM Pic for the 0.2 Liter (~7 oz) info back in 2020. Put pic below of where the oil level check plug was located.
Highly doubt I would have an issue with my interpretation of change DCT at 7500 miles BUT just in case could use that pic!
just follow
and adjust the future changes by mileage and time for future transmission service.
thats exactly what I did.
the engine oil change
light came on at 6300 miles and I called the service department to service the engine oil change and at the same time did the transmission filter change on my last service.
I guess 7500 miles isn’t written in stone as many here would like to suggest.
thanks for posting that photo and that information up.
It also says clearly, Dual-Clutch Transmission filter MUST be changed during the FIRST oil change! Frankly used that GM Pic for the 0.2Liter (~7 oz) info back in 2020. Put pic below of where the oil level check plug was located.
Correct? I mean, if you interpret all these requirements literally....
GM isn't going to care when you tell them "The guys on Corvette Forum said I didn't have to change it at 7500 if I change it early." If you think following GM's warranty requirements, which say you need to follow the recommended service schedule, is "****," that's up to you I guess.
its 15000 miles additional from the first filter change and that’s according to the GM service rep who texted me their answers so I have it in writing but to be on the safe side changing the filter again at only an additional 7500 miles wouldn’t be the worst thing.
I have had 3 transmissions in my c8 and it’s not really fun.
better to be overly cautious and not miss the mileage between changes as written in the owners manual.
after my transmission experience Id rather error on the side of caution
for the few dollars it costs for service stay properly within the mileage and time difference between change intervals
its not as I stated 22500 more after the first filter change. It’s 15000 miles after the first filter change according to the GM rep that texted me this information
so
for round numbers if you changed your filter at 5000 miles on the odometer. You then change the second filter at 20k miles on the odometer and then change the filter again at 42500 miles
if you are having the 3 year fluid change change the $127 filter at that time as well. Then go 22500 miles from that mileage point and you are good to go according to the GM rep who wrote instructions to me.
I hope this helps
jmo
This has zero to do with forum advice. Follow the written manual not somebody's personal opinion on these forums.
Apparently some forum gurus have their own advice and interpretation
how come you ignore that written part of the owners manual as you keep repeating exactly at 7500 miles for the filter change?
you can’t have it both ways to annoy people.
GM isn’t looking to screw people if the vehicle breaks.
just use common sense and you’ll be fine.
(edit) GM warranty was excellent in their effort to replace my cars transmission when it stopped working not once but twice)
those new to GM vehicles GM is driven to deliver excellence.
(Humor)
Im handsome and charming but that’s not why GM delivered excellence in
my situation.(end of humor)
They do it for everyone so their reputation stays as is or is improved if that’s even possible.
call them up. Get the answer from the horses mouth in a text , screen shot the directions their customer service rep gives you and follow their instructions
that’s my advice, that’s my experience, that’s my opinion.
how
much better can you get than getting it in writing from the GM representative.
