The only way you can break the sleeve on those Titan sockets is by not knowing what you are doing. I have two 19mm, 21mm and 22mm and none of them have a broken sleeve. AND, I've used them with impacts occasionally which, probably shouldn't do.
Since this comment seems to be directed to me why don't you educate us on proper use of a socket🤣 I'm interested since a have over 50 years experience
I use a breaker bar to loosen the lug nuts and then an impact to get them off. I hand install the nuts for a turn or so then set the impact for the lowest torque setting and spin them on. Then I use a torque wrench to tighten all 5 nuts to 50% of the torque valve, then 100% of the torque value. If I feel real 'picky" my second tighten is at 75% of the torque valve, then I do 100% torquing. Do not use any lubrication on the studs/nuts.
