Sponsored by: Wheel Design
Non-marring lugnut socket?
Old Jul 23, 2023 | 07:23 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Default Non-marring lugnut socket?
Can someone please direct me to a quality non-marring lugnut socket kit ? I see there are a few on amazon but have mixed reviews. Thanks!!
Popular Reply
Jul 23, 2023, 07:56 PM
RKCRLR's Avatar
RKCRLR
This is what I use:
Amazon Amazon
Old Jul 23, 2023 | 07:51 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I got mine at Harbor Fre8ght. Nylon coated, seem great for as often as I use them.
Old Jul 23, 2023 | 07:56 PM
RKCRLR's Avatar
RKCRLR
This is what I use:
Amazon Amazon
Old Jul 23, 2023 | 09:36 PM
Shirl's Avatar
Shirl
Great! Thank you both!
Old Jul 23, 2023 | 09:44 PM
Kracka's Avatar
Kracka
I get all mine for each vehicle at AutoZone. I've been using them for years and they hold up fine with repeated impact use too.
https://www.autozone.com/ratchets-so...ket/453038_0_0
Old Jul 23, 2023 | 09:50 PM
RMS73's Avatar
RMS73
This mine:
Amazon Amazon
It gives more space between the fender and my hand when using the torque wrench
Old Jul 23, 2023 | 09:53 PM
Thanks for the recommendations. I could use a no-mar lug socket so will look these over.
Old Jul 23, 2023 | 10:38 PM
mortelec's Avatar
mortelec
Use a 22mm with the plastic/ nylon outer. The 7/8" fits but knocks up your lugnuts. Alot of tire shops probably grab a 7/8" which is a little too loose.
Old Jul 24, 2023 | 01:09 AM
Zormecteon's Avatar
Zormecteon
The one from post #6. ..... That extra length keeps the wrench far from the body and wheels... !
Old Jul 24, 2023 | 07:04 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by RKCRLR
That is what I use. BUT see many that only have the outer plastic protection. Helps the wheel BUT not the lug.
I had used the one in pic below for ~10 years on my C6 and C7 Vettes. It has a hard plastc inner part that touches a lug. But now over $35 if you can find and none for 22 mm lugs. Frankly dout it would hold up well with 140 ft-lbs.
Note the 22mm Titan has rounded corners that prevent the steel inner from contacting the lug nut corners. Has worked fine.
I also use a short extension (called 1 1/2" but it fits flush) and only ends enough length so my torque wrench just clears my fenders. Closer the better as easy to get 140 lbs using two hands and legs! No strain on lower back!
Old Jul 24, 2023 | 09:58 AM
feeder82's Avatar
feeder82
I have the titan socket in the links provided that lasted 2 uses, my review on Amazon is one of the 1 star. I noticed the first time i used this socket the plastic sleeve slipped and spun.
​​Junk IMHO
Old Jul 24, 2023 | 10:08 AM
Kracka's Avatar
Kracka
​​Junk IMHO
Why does it matter if the sleeve slips/spins? It's only purpose as a cover is to protect the wheel from metal-on-metal contact. I have a set in 17-22mm and have yet to have one fail on me after years of use.
Old Jul 24, 2023 | 10:49 AM
feeder82's Avatar
feeder82
This is why it mattered, it broke
Old Jul 24, 2023 | 10:59 AM
RacerRik's Avatar
RacerRik
If care about not damaging your lug nuts, never use or let a shop use an impact tool on them.
Old Jul 24, 2023 | 11:00 AM
RKCRLR's Avatar
RKCRLR
Yours looks like it is the 19mm version, perhaps the 22mm version is better. I haven't had any problems with my 22mm but I don't use it with an impact wrench either since I don't want to mar the lug nuts.
Old Jul 24, 2023 | 11:27 AM
jay21's Avatar
jay21
I do mine by hand and a 25" breaker bar. Never an impact. The socket is wrapped in electrical tape. Never a mark. Top of socket does not touch the bolt. Simple ,cheap, effective.
Old Jul 24, 2023 | 12:19 PM
feeder82's Avatar
feeder82
Yes it is the 19mm. just my experience with this brand, nothing more, take it for what it's worth. I break my lugs loose with a bar then remove with the impact.
To Non-marring lugnut socket?
Old Jul 24, 2023 | 01:00 PM
JerryU's Avatar
JerryU
Yep! In fact, for the ~10 years I posted my plastic inside lug socket a few commented about it not having a plastic outside! As I would NOT use a powered wrench on my wheels NO NEED. Also, IF that was a concern would wrap with electrical tape. The issue is the lug nut not the wheel. That is controlled by the use of the proper wrench!
No-Mar socket I used for ~10 years on my Vettes. BUT not available in 22mm and wonder how it would hold up with 140 ft-lbs. Have found the Titan works fine with my breaker bar, 1/2-inch drive ratchet and torque wrench.
Old Jul 24, 2023 | 02:08 PM
Newdude's Avatar
Newdude
The only way you can break the sleeve on those Titan sockets is by not knowing what you are doing. I have two 19mm, 21mm and 22mm and none of them have a broken sleeve. AND, I've used them with impacts occasionally which, probably shouldn't do.
Old Jul 24, 2023 | 02:57 PM
bhvrdr's Avatar
bhvrdr
Originally Posted by RMS73
This mine:
https://www.amazon.com/dp/B01MUI6G5H...?ie=UTF8&psc=1
That's the one I use
