C8 center stack switch LED brightness
Am I the only one or does anyone else think the LED’s need to be brighter. In daytime light I can not see the LED’s unless I put my hand over them. These are the lights for the center stack control functions. Has anyone done anything to make them brighter?
The following 13 users liked this post by argo22:
BearZ06 (07-27-2023),
bigmike32172 (07-30-2023),
cmonkey713 (07-29-2023),
David 2024 (02-26-2024),
Didier9 (07-27-2023),
and 8 others liked this post.
AMXJim (02-25-2024)
Yup, terrible design.
Received 19,795 Likes
'20-'21-'22-'23-'24
Not sure how hard it would be to access the stock LEDs, but I would bet some of the lighting vendors could give you some advice on how to install brighter LED lights.
If you go to YouTube and look up “squirrel cage garage” that guy shows how to take the whole dash out on a C8, so he probably shows how to access the switch assembly. But I hope somebody knows how to change the LEDs
Agreed, I have found the same thing during daylight hours. They really would need to tie them into the dimmer, if you make them brighter during the day they likely would be too bright at night, so would need to be able to adjust them.
Received 7,191 Likes
I've gotten used to them and really not much of a problem for me...I simply slide my right hand, slightly cupped, alongside the buttons and then press with my thumb if I need to change a setting...
The following 5 users liked this post by tadda:
Broken Halo (07-30-2023),
myc8vette (11-27-2023),
R23HTC (07-31-2023),
TNBatmobile (02-26-2024)
Received 2,155 Likes
Lot's of guys here bitch over the most stupid things.
Life's too short. Tremendous number of great things in the C8 and guys gripe about cupholders and LEDs.
The following 4 users liked this post by Vega$Vette:
Yeah, we like to bitch about LEDs and cupholders (actually the cupholders on the C8 are fantastic compared to the ones that were on the C7....could they have been improved on the C8 as a result of our bitching?) and other minor flaws, because that's what people do on forums. Some bitch about the square wheel (I love it), others bitch about the stereo (I have mixed feelings on that one), and complain about any number of other small inconveniences.....because you know what?.....the C8 is fantastic but not perfect.
The following 2 users liked this post by STINGmole:
SunnyDaze (07-29-2023),
hamta (07-29-2023)
I’m just saying we are all lucky, fortunate, worked had enough to have a C8.
So why not just be thankful and enjoy the Vette GM has designed and delivered instead of focusing attention on petty issues?
The following 3 users liked this post by Vega$Vette:
It’s daytime.. of course you can’t see them. Lol.
The following 2 users liked this post by TD20:
tadda (07-29-2023),
Vega$Vette (07-29-2023)
Given the choice of removing the entire dash and pursuing an unknown solution to make the "great wall" LED indicators brighter or cupping my hand over them to see if they are "on," I think the choice is a good measure of one's sanity.
The following 2 users liked this post by Foosh:
M2Pilot (07-31-2023),
I've never been in a C8, except for two laps driven by an instructor at Spring Mountain. How is the infotainment screen and the driver's display screen.......can you see everything here in daylight? I assume the C8 HUD can't be seen in daylight, it can't in my C6. No problem with displays in the C3s..
The HUD is plenty bright in the brightest sunshine. It is vastly improved over the C6 HUD.
68/70Vette (08-07-2023),
plasboy (07-29-2023)
I tap the climate icon on the main screen and use that to make changes. Like you I can’t see them either.
The following 2 users liked this post by 2024VETT:
langhorne_bill (07-29-2023),
RobertC8 (07-29-2023)
For the HTC it is even worse, I do the hand cup technique to be able to see them on a bright sunny day with the top down.
R23HTC (07-31-2023)
It could not be perfect for everyone since expectations differ but like for everything else, the squeaky wheel gets the grease
It goes to the product team talent that we have time to gripe about such small details. That means they got an awful lot right.
