TPMS Nut Replacement
Quick question for ya all... I have Gloss Black rims and want to replace the ugly factory aluminum tpms nuts with black. Can this be done without loosing the sensor or loosing air??
I would think you could replace them but just don't want an issue..
Thanks for any help!!
NCM Lifetime Member
Received 3,936 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23-'24
Yes, I just recently replaced mine when I changed to black wheels. Just take the old ones off with a 12mm deep well socket and put the black ones on.
The following 3 users liked this post by lewislgZ06:
Yes Amazon sells them, very easy to do. you will not lose air. when you install them do not over tighten just lightly snug only. The brand is Muzzys store, universal black $14.99 they are in stock.
Action Andy (10-02-2023)
As long as you have pressure in the tires, you'll be fine.
Tire Rack also offers TPMS valve nuts in choices of silver or black. I'd be wary about ordering something like this from Amazon, but TR does a good job of ensuring that whatever they ship is compatible with particular makes and models.
Received 8,868 Likes
I'm sure it's the exact same Chinese nut that is sold on Amazon. Plus Amazon returns are simple if you have an issue.
Received 19,378 Likes
'20-'21-'22-'23-'24
Sounds like a simple swap once you decide which TPMS nut to go with.
NCM Lifetime Member
There are however 2 different lengths (long or short) available.
I ordered the short version first, but ended up ordering and using the long ones to fill the gap between the valve cap and the nut/sleeve.
OEM (Note the gap between the valve stem cap and tpms nut/sleeve)
Aftermarket longer tpms nut/sleeve that fills the gap.
Final tpms nut/sleeve and valve stem cap installed on gloss black MRR F23 wheels
NCM Lifetime Member
No issues at all. I’ve even bought an additional set since and have them on my new Z06 that I got about 3 weeks ago.
NCM Lifetime Member
These are the ones I got.
https://www.amazon.com/NNR-Aircraft-Aluminum-Anodized-Finish/dp/B0BZ9R52JL?pd_rd_w=bzrwU&content-id=amzn1.sym.452c3ac5-14f8-4a5d-834c-a18a40246a9b&pf_rd_p=452c3ac5-14f8-4a5d-834c-a18a40246a9b&pf_rd_r=6CMYKTW3MYW4R1JS7TJD&pd_rd_wg=ysuu5&pd_rd_r=495ddf03-2e25-4ca6-9e22-e1d99c4253a6&pd_rd_i=B0BZ9R52JL&psc=1&ref_=pd_bap_m_grid_dv_rp_0_1_ec_ppx_yo2_mob_b_ts_rp_5_i
